brake/fuel lines, AGAIN
Old 09-18-2009, 01:00 PM
eric1115's Avatar
Originally Posted by ayoung101
that's the main problem i'm having. there's a small (8"?) flex hose coming from the fuel pump, ending in a female connector. then there's the roughly 6' long metal fuel line, which is the one that i broke. then at the other end, there's another (12"?) flex line that goes into the fuel filter with a female connector. i can't find mating male tube nuts to those 2 female connectors on the flex hoses.
I know this is an old thread, but thought this could save someone some headaches in the future...
Edelmann part number 121069 is the 14mm x 1.5 male fitting that goes on the end of the 5/16" main fuel line. I know O'Reilly's orders from Edelmann, and I'm sure a bunch of other parts stores do too.
Eric
Old 09-20-2009, 02:02 PM
Flash319's Avatar
Cut the flares of and use a rubber joiner with fuel line hose clamps. Done.
Rickstwowheels
09-10-2015 03:51 AM
Duppie007
08-25-2015 11:51 PM
Duppie007
08-25-2015 03:05 PM
pyramid
07-30-2015 10:05 AM
Fundy Rider
07-16-2015 01:35 AM
Quick Reply: brake/fuel lines, AGAIN
