brake bleeding question
Old 10-21-2022, 12:09 PM
87-4runner's Avatar
Whatever steps you take is your choice. The bottom line is, if you have air in the system you'll have at best soft pedal brakes. If, you have no air then you probably can expect a solid pedal.
The following users liked this post:
briholt (10-21-2022)
Old 10-22-2022, 11:50 AM
2ToyGuy's Avatar
Originally Posted by briholt
It does. I read the fsm several times and just didn't see the item about lspv because, again as far as I can tell, it doesn't say specifically that driver rear is furthest. I was looking for that and just didn't see it.
This is what I have in the 86-89 FSM.
It's not VERY specific about which is longest hyd line, but you can see it specifies the LSP & BV last. That's what I've been going by. It seems to work pretty well for me. I owned an 87 4Runner up until very recently, like about a year ago. I did it the same way. LSP & BV last.
I found with it, strictly by accident, that removing the axle end of the bar for the LSPV, and moving it through it's throw a few times, really makes a difference. It sort of cleans out the trash that collects in the valve, and when you bleed it, all the crud comes out. It's easier than stripping the valve apart, in any event. IF it works. If the crud and corruption has gotten so thickly packed in there that this doesn't work, THEN you need to strip the valve down.
Good luck to ya!
Pat☺
The following 2 users liked this post by 2ToyGuy:
briholt (10-30-2022), coopster (10-22-2022)
Old 10-27-2022, 07:29 AM
YT Community Team
Jimkola's Avatar
Boy, does gunk accumulate at the LSPV. A good argument for periodically removing and cleaning out could be made. The fluid was so dark and thick when i disassembled I thought for sure everything was rusted , but when I cleaned it looked pretty pristine.
2ToyGuy (10-27-2022)
Old 11-03-2022, 12:20 PM
Blueman's Avatar
I highly recommend a power-bleeder. Motive Power Bleeder #0101
Then it's a one-person job.
fountain
12-31-2015 06:08 AM
Whatever123
09-30-2015 12:12 AM
CanRunner
07-20-2015 01:29 PM
87turboPA
07-12-2015 07:49 AM
87turboPA
07-09-2015 05:58 AM
Quick Reply: brake bleeding question
