brake bleeding question
also has 3 brake lines connected to it- one from the rear circuit on the brake master cylinder, one from the front circuit (should be tee'd in by the passenger side front wheel) and one line that goes down and splits to the rear brake cylinders.
You will need two people. One person in the truck in the driver seat and one to open and close the bleeder value, the values should be on the bottom of the caliper on the front brakes and in the back side of the brake plate thing for the back brakes. The person at the value opens the value and tells the person in the drivers seat to push down the brake pedal, then close the value and when the value is closed have the person let off the brakes. So basically open value, pushdown pedal, close value, and let off brake. I'm not positive about the value placement but it should be close, I've never bleed the brake on my yota but I have on friend's cars and it's the same on all cars, but I would understand if you waited for more advise.
good stuff. on the bleeder valves when the 2nd man in the driver seat pushes the pedal down, fluid should come out right? then close them up
cool so just keep pumping to where it would normally stop then close the valve till a smooth stream of fluid comes out. awesome thanks brothers
correct order for bleeding 85-95 22re
Sorry for the revival of an old thread.
So, in my searches for bleeding a brake on our trucks (mine is 91 pickup 4wd 22re) I've seen various claims of the proper order.
The most general claim making the most sense is to bleed the longest brake line first, moving to the shortest brake line.
our trucks often have the lspv. I think mine is located just above the passenger rear tire, making it a tad shorter than the passenger rear..
So, it seems to me that the correct order would be
What am I missing?
Thanks all
- Drivers rear
- Pass Rear
- Lspv
- Pass front
- Drive front
What am I missing?
Thanks all
Toyota says: Master Cylinder, longest brake lines, then LSP & BV. http://web.archive.org/web/201203161.../3checksan.pdf
But if you'd rather go with "people say," be my guest.
I've always done the LSPV last, for the last 30+ years on my 87 Hilux, anyway, and it's worked very well so far. It IS what the FSM specs, so I figure it's the right way to do it.
Does that help at all?
Pat☺
Pat☺
The following users liked this post:
briholt (10-20-2022)
The fsm I have does not give specifics.
What was helpful was that link. When I read my fsm I didn't see any mention of which line was longest, so I missed the lspv in item 6.
