Bouncing Idle
Old 06-08-2008, 07:21 AM
Troph's Avatar
Bouncing Idle
my 92 22re has had this problem for a while just never got around to fixing it. it runs fine cold (above 3k) but once it warms up the idle bounces like it has a vacuum leak but i cant seem to find any hoses that are off/missing and iv sprayed starter fluid all over the engine bay and it didnt rev up. any suggestions on what it could be besides a vacuum leak?
Old 06-08-2008, 11:02 AM
just a 22re's Avatar
gaskets, idle air valve, crack in the head, intake ect.., cam lobes ground down, low fuel puressor, a very very huge cam?
Old 06-08-2008, 12:50 PM
TORTIS's Avatar
coolant temp sensor maybe. is it using coolant?
Old 06-08-2008, 02:56 PM
iamsuperbleeder's Avatar
Originally Posted by Troph
...it runs fine cold (above 3k) but once it warms up the idle bounces like it has a vacuum leak...
When cold it idles around 3k; as in 3 thousand rpms! That's a little high for a cold idle. Even when my idle wasn't set right and it was idling high, it was just above 2k, and I didn't like that.
You have AC? Sounds like maybe the idle-up valve or the VCV hooked to id may be sticking open. You wouldn't hear any leak in that case since it's a closed loop of vacuum lines, but it will cause an iratic idle; almost like a constant lope. Does turning the AC on change the idle; as in making it idle normal?
sanctfy
All Other Toyota Swaps
09-15-2015 02:52 PM
JefferDean
07-31-2015 10:39 AM
DrZero
18
07-24-2015 11:31 PM
luckypig44
07-19-2015 11:25 AM
shisha1999
07-13-2015 11:09 PM
Quick Reply: Bouncing Idle
