Bought a wiring harness to swap into my truck. Problems!!!!
Old 09-25-2007, 05:34 PM
vietsol's Avatar
Hey guys. I just bought a wiring harness for my 1990 truck and I ran into some problems. I started just swapping the harness and I found that the coolant temperature sensor and fan switch had different plugs. That was no biggy, I could get new ones.
But then, I noticed that the new harness had a diagnostics box while mine did not. Another problem I ran into was my wiring harness has a resistor box while the new one did not.
Then the biggest issue was that the fuel injector plugs were different too. Did I get completely the wrong year? or is mine screwed up in the first place? If someone could help me clear this up, it would help me a lot! Thanks in advance!
Old 09-25-2007, 05:37 PM
Guardian_Saint's Avatar
You should of gave them your part # from your old wire harness so they know what year and model your truck is.
Old 09-25-2007, 05:40 PM
corvey's Avatar
That's why I like the idea of having the doner vehicle right next to you...
rdlsz24's Avatar
What truck is the donor harness from?
Rob
Old 09-25-2007, 08:18 PM
vietsol's Avatar
well, a guy sold me a harness and ECU and when I looked up the ECU number, it came up as a 1990 4spd-MT 22re truck. But I'm beginning to think maybe it was a 1990 ECU, but maybe a different year truck.
Old 09-25-2007, 08:24 PM
ozziesironmanoffroad's Avatar
i really hate saying this, but your 100% best bet is to go to the stealership. if THEY mess up, then its on them and you can get an exchange. private sellers rarely give you your money back. im just wondering about that ECU... im not sure if you have to have the ECU from that year, or if an ECU from ANY 22RE will work.
Old 09-25-2007, 08:35 PM
Jeenyus04's Avatar
i could be wrong but i dont think there are any 1990 4 speeds out there..
Old 09-25-2007, 08:37 PM
vietsol's Avatar
http://www.enginecontrolunits.com/ca...ICKUP/1990.htm
the ecu that came with my harness and stuff has part number 89661-35160
lists as federal 4spd-MT
Goddamnboh
3.4 Swaps
12
05-11-2016 09:22 PM
greenbuggy
06-28-2015 10:40 AM
TheManOutside
06-18-2015 03:32 PM
Yoda
06-23-2002 09:39 AM
Quick Reply: Bought a wiring harness to swap into my truck. Problems!!!!
