Best Junkyard Mods
Old 01-02-2015, 09:24 PM
  #501
bpealer's Avatar
Spotted an isf bracket lift today. Still deciding if I should go back for it
Old 01-02-2015, 09:26 PM
  #502
Gargoyle_Runner's Avatar
I installed an auto dimming mirror that helps me maintain my lazy status. It was in a bin full of rearview mirrors at the local yard for 7 bucks with the plug and @8"s of wire. Did some searching on the interweb and figured out how to wire it in. I have an 86 SR5 Runner with the map lights so the power was right there. Picked up some window adhesive from the local parts store and presto. The mirror is a bit larger than stock also which is nicer than I woould have thought.
Anybody know of a good salvage yard in NW Washington? Only one near me, 30 minutes, and it's not very big. Like most, the yota trucks are often cleaned as they are put in place.
Old 04-23-2015, 12:49 PM
  #503
foppert's Avatar
Went today and nabbed two of the retractable underhood lights from an 80's suburban. Gonna convert em to led and put one on the back of the runner and one under the hood. I'm done with crappy flash lights.
Old 08-16-2015, 06:56 PM
  #504
maco35's Avatar
Bump!
Old 08-16-2015, 09:07 PM
  #505
mr_manny's Avatar
LED conversion...smart
Old 08-16-2015, 09:16 PM
  #506
v_man's Avatar
Junkyard you say ?!
Pick n' Pull in San Jose...
I picked a stock gas tank skid plate for my 90' rock crawler...
I welded some rebar to stiffen it up and add some strength
some paint...
and install...
total cost was about $35 , and I don't worry about taking a gas tank hit anymore...
Old 08-19-2015, 04:53 AM
  #507
zchead's Avatar
Subscribed
Headed to my local pick and pull today. I'll let yall know what I find.
Old 08-19-2015, 08:56 AM
  #508
zchead's Avatar
Score
Found an e-locker out of a 99 Tacoma for $200 and if the gear ratio is different getting the front as well for $200
Old 01-30-2016, 04:51 PM
  #509
allgoodian's Avatar
Thumbs up junkyard mods for my 85
V6 calipers from a 1993 runner....also the booster and master....added rear shoulder belts from a second gen....power driver seat from a solara.....center console from a 02 camry with cup holders!!! also an overhead console from a late 90's Yukon with homelink....and a rearview mirror from a late 90's gmc 1500 with compass and temp and auto dimming
Attached Thumbnails Best Junkyard Mods-overhead.jpg   Best Junkyard Mods-booster.jpg   Best Junkyard Mods-center-console.jpg   Best Junkyard Mods-rear-belt.jpg
Old 01-30-2016, 04:57 PM
  #510
bpealer's Avatar
I like the overhead console. Too bad I have a moon roof or I'd do the same
Old 04-25-2017, 06:03 AM
  #511
se7enine's Avatar
Volvo battery cables are nice and clean looking. The ground comes with spade terminals you can mount to the fender wall. Just $5 at the junkyard.
Old 10-09-2017, 06:01 PM
  #512
JShara's Avatar
I'm sure other guys have thought of this but junk yard mods on my truck are Scion tc fog light switches. They fit into the factory holes in the dashes of our trucks. I plan on using them to run auxiliary lights. They look so much better than clunky toggle switches. Also snagged a power antenna from 94 sr5 4 runner. I plan on running it with a manual switch so when I'm about to get on the trail I can lower it. Also snagged early 90's Chevy caprice license plate frame. It's on hinges so I was thinking of tucking my hitch up as it hits sometimes.
Old 10-09-2017, 06:03 PM
  #513
JShara's Avatar
Old 02-05-2018, 05:27 AM
  #514
se7enine's Avatar
If you are looking for a nice set of sealed relays you can find some on 2nd Gen Blazers/Jimmys on the passenger side of the firewall. I found some that had Bosch and some that had Hella. Good mounting bracket too.
Old 02-05-2018, 06:35 AM
  #515
rancherman's Avatar
Next week; Leather seats from VW Passat. Not sure I'll demand the heated ones, but I gotta do something about my current 'flat as pancake' originals in my 1994 pickup.
Old 02-05-2018, 11:32 AM
  #516
RAD4Runner's Avatar
Nice! Tnx for the tip.
May we know what current rating?
Do the pins look same as "common" all -purpose automotive relay?
pins 30, 87, (87a), 85, 86?
Old 02-05-2018, 05:27 PM
  #517
se7enine's Avatar
SPDT 12v 40amp. Same 5 pins but different size. I think ISO 280. The layout is also different but labeled.
Here is and un-skirted relay with same pin-out.
Old 02-06-2018, 12:22 AM
  #518
RAD4Runner's Avatar
Sweet! Thanks. Yes, easy to use for our mods.
TheBFA
02-15-2020 06:55 AM
punks_is_4x4
05-31-2016 06:03 AM
voiddweller
53
02-01-2016 05:46 AM
oldblue
09-28-2015 04:07 PM
Project90
09-24-2015 11:40 PM
Quick Reply: Best Junkyard Mods
