bellhousing bolt size....
Old 12-02-2006, 10:50 AM
highway's Avatar
Could someone tell me what size socket I need to fit the bellhousing bolts on a 1989 yota 4x4. I read here that I needed a wobble socket to fit the top two bellhousing bolts. I'm going to tackle installing a new clutch next week ,so I am rounding up the tools i need..... any tips to make it easier ?
highway
Old 12-02-2006, 10:54 AM
DudeBud's Avatar
17mm 14mm 12mm ites very easy to drop the tranny with the crossmember with a jack and go for the top two bolts that way
Old 12-02-2006, 03:26 PM
toyaholic's Avatar
jack the front up and you can get to the top two bellhousing bolts with a box end wrench and a cheater pipe or shear muscle power through the wheel wells. if you have a really long extension and a swivel socket or a knuckle you can come from underneath by the transmission or you can do it the really difficult way from above with the hood off in between the back of the head and the firewall. i find it very easy to get to from the wheel wells. a flash light and a close look and you can find them from there.
Old 12-06-2006, 10:36 AM
highway's Avatar
thanks
Old 12-06-2006, 10:52 AM
ewong's Avatar
Assuming a W56 trans...
I use the LONGEST Craftsman 1/2 drive extension bar (24"?) and and go through the tranny tunnel. This is after the tranny cross member is removed and the trans tipped back a smidge.
The ribs on the bell housing guide the socket on to the bolt
17mm or 19mm - I ferget which.
Do NOT try this with a 3/8 extension bar - or you will discover how Torsion Bar springs work
BTW - this is also how I FILL the trans - mucho easier to go via the stick shift hole. On the later models with the forward shifter - you cant fill the transfer case this way tho...
Old 12-06-2006, 11:02 AM
Bill's Avatar
I second dropping the tranny a little bit. Made my life a whole lot easier.
Also, if you have an air ratchet, it will save you a ton of time. There is a good 1 1/4" of thread on those bolts, and it's a pain with a regular ratchet.
Old 12-06-2006, 01:41 PM
ZUK
ZUK's Avatar
highway
Those 2 upper bellhousing bolts you refer to are 17mm....and I thought it was kinda easy to get to them thru the engine bay with a long closed end wrench. That was on my 92 22RE 5 speed. No body lift. There is room to wrench there.
Old 12-06-2006, 02:23 PM
toyotaoffroad91's Avatar
for the 2 uppers get a 3 foot extension and take the go through the shifters from the inside with a breaker bar on there. off in 4 minutes
Old 12-06-2006, 05:03 PM
kyle_22r's Avatar
on an '89-95 truck i can get the top 2 bolts with a shorty 17mm wrench. much easier than playing the socket/extension game, at least for me. hardest part is if everything's original, it takes a LOT of force to bust them loose.
Old 11-11-2014, 01:55 PM
Tstew's Avatar
Are there 8 bolts in total? Does the top starter bolt count? I'm working on an 83 and assuming its the same. I see two bolts on the bottom and the two on top and the starter bolt that I already removed... thanks for the help!
some drunk guy
08-03-2021 06:09 PM
Zach_trun
01-22-2020 04:42 PM
JUICE222
10-13-2015 08:50 AM
Jwp1
09-06-2015 11:03 AM
Quick Reply: bellhousing bolt size....
