BEGINNER'S 22re Timing Chain Failure / replacement / head gasket replacement
#261
I am not sure of the picture numbers. It must be a phone or mobile device thing.
That is an inspection / access plug for automatic transmissions that Toyota calls:
PLUG, HOLE (FOR REAR END PLATE)
TOYOTA PART NUMBER: 90950-01458
Part Number Category: 11355A (Shown below)
Diagram Source: parts.toyota.com
The following users liked this post:
22marv (02-16-2019)
old87yota (02-16-2019)
#263
22marv -
By now you've figured out that the "numbers" you're citing are an internal CDN format. They change not only every time you come to the forum, but as you are scrolling through the forum. So no one (not even you) can find the picture from that number.
Instead, refer to the post number (52), or much better, attach a link: https://www.yotatech.com/forums/f116...l#post51457948
And for you, the best would be to just tap the "quote" button. Delete out all the stuff you don't care about (use an ellipsis ....), and we can not only see the picture, but the context.
Welcome to YotaTech.
... and oh yeah, on an automatic (i don't know about the 5 speed)...you have this thing. a rubbery / undercoated-covered, oil-covered, deformed, mis-shaped plug...i assume it's some sort of inspection plug for the transmission.......put it in BEFORE you put the pan on....i didn't, and had to get it into place with alot of finesse afterwards.
Attachment 186453
Attachment 186454
Attachment 186453
Attachment 186454
22marv (02-16-2019)
#264
Thank you very much for the info and tips. I’ve had 3 Toyota Pickups, 4 Tacoma’s, and now a Tundra, and this was the first time I was ever stumped on a part... I knew this site wouldn’t let me down!
voiddweller
19
05-02-2016 09:10 PM
