Bed compatability questions
Old 05-04-2010, 01:37 PM
xxxtreme22r's Avatar
Will an 89-95 bed fit an 87 body? If so what other problems might I run into. Also does anyone think it might look a little wierd with the different body lines?
I search but really couldn't find what I was looking for.
Old 05-04-2010, 01:51 PM
shawns88's Avatar
mine has a 92 bed and it bolts up fine, i didnt put it on, and it has some rear body work.
Old 05-04-2010, 01:54 PM
shawns88's Avatar
and my trucks an 88, cant poast pics for some reson but i have pics on my album
Old 05-04-2010, 02:06 PM
tried4x2signN's Avatar
Location: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
If you've got an address bar, you can post a link to the pics...
If you've got FireFox and it's in your album, then you can right click and copy image location then paste that in the insert image box..
Old 05-04-2010, 02:13 PM
what he said, would like to see pics.
Old 05-04-2010, 02:29 PM
shawns88's Avatar
said invalid url but i got em up, had to re name them
Attached Thumbnails Bed compatability questions-user63759_pic10677_1272735161-1-.jpg   Bed compatability questions-user63759_pic10679_1272735349-1-.jpg   Bed compatability questions-user63759_pic10678_1272735349-1-.jpg
Old 05-04-2010, 02:31 PM
shawns88's Avatar
the pasenger side has no body work on it,
Old 05-04-2010, 02:34 PM
surprisingly it doesn't look that bad. body lines almost line up.
Old 05-04-2010, 02:38 PM
shawns88's Avatar
yea, all the bed mounts line up to so you should be good.
Old 05-04-2010, 02:40 PM
MaK92-4RnR's Avatar
Tacoma bed swap. enough said.
Old 05-04-2010, 02:43 PM
that would be good too, but I found a bed around here the guy only wants $250 for it.
Old 05-04-2010, 02:45 PM
shawns88's Avatar
thats not bad, i found 1 to but he wants 500, i bought my truck for 200 bucks mor than that lol
Old 05-04-2010, 03:15 PM
OrRunner's Avatar
wish you guys were closer, i got an 84-88 short box complete, straight and no rust, just needs paint, and i cant give it away for 100.00 out here!!!!!
Old 05-22-2010, 03:03 AM
gonna bump this for one more question, is there a big difference between the 4wd and 2wd versions of these beds? I know there is a difference in the front fenders but unsure as to what and how much. Thanks.
Old 05-22-2010, 07:31 AM
streetlancer's Avatar
I'm thinking the only real difference are the body lines. The 4wd had bigger wheel flares than the 2wd, which looks better. But i have seem many 2wd trucks with the 4wd style beds and surprisingly they are in better condition than the 4wd in regards to rust cancer. Too bad i could never find a 2wd with the 4wd style bed in any of the junkyards.
Old 05-22-2010, 03:43 PM
slacker's Avatar
it will swap as suggested above .. 6 of the 8 bolt mounts line up .. and tail lamp pigtails are the same . Fuel filler is different , but if you can get the original filler tube , it makes things much easier . the bed itself is larger/wider then the stock unit .. it will stick out on each side about 1/2 " when centered .. and with the mount pads eliminated , you can get the body lines to be close ...
Old 05-22-2010, 05:45 PM
thanks for the input guys, gonna keep searching for a 4wd bed.
Old 07-22-2010, 09:50 AM
gross, but yeah a 89-95 bed will fit a 84-88 truck...
http://nashville.craigslist.org/ctd/1855825712.html
Old 07-22-2010, 10:06 AM
is it me, or dose the wheel base not match up in the rear end, ie the 84-88 is shorter than the 89-95.
Other than that the body lines match up a little better than I thought.
o2raybid
09-04-2015 12:45 PM
Tigbucket
07-30-2015 07:29 PM
TransAmBandit
07-28-2015 11:30 PM
DrZero
18
07-24-2015 11:31 PM
Quick Reply: Bed compatability questions
