ball joint spacers is this really a good idea
Old 03-17-2009, 07:04 PM
iamsuperbleeder's Avatar
wow Matt, BJ-spacers sure made your truck dirty
Old 03-17-2009, 08:26 PM
94exblack's Avatar
not scared off, working. And trying to work on my truck and be a dad all at the same time who needs sleep. Once I saw the pic of the truck with the spacer on one side only at full droop, it made alot more sense to me and I think I will try to fab up some on my own 100 bucks seems pricey for what is involved. I would imagine steel would work just as well as aluminum. I do appreciate everyones comments
Old 03-17-2009, 09:27 PM
abecedarian's Avatar
Over all, steel would work as well as aluminum but AL saves a little bit of weight so the shocks don't work as hard (yeah, not a lot of weight, but some).
and you'll still have to mod the upper arm (ie: cut it) to give enough clearance for the spacer to bolt up.
Old 03-18-2009, 09:16 AM
pitster33's Avatar
I have bought 3 sets of these and installed them on my personal rig, and two of my buddys rigs and they are holding up well. We beat are trucks and even jump them a little bit.
Old 03-18-2009, 10:56 PM
  #25
Texas91Runner's Avatar
did any of you have to cut the a-arms to fit the spacer in there?
Old 03-18-2009, 11:38 PM
  #26
Matt16's Avatar
We all did. You have to. The cut is not going to weaken the UCA.
Old 03-19-2009, 07:56 AM
  #27
pitster33's Avatar
you pretty much just trim the little bottom lip back. I used a sawzall and a basic grinder to get them perfect.
Old 03-19-2009, 09:20 AM
  #28
oh alright. i took a look at the arm and it looked like i could squeeze a bj spacer in there without having to do any trimming, but that's not too much work to do. what shocks did you guys use?
Old 03-19-2009, 09:27 AM
  #29
4Crawler's Avatar
I have a list of some common front shocks for use with the ball joint spacers on the web page below:
http://www.4crawler.com/4x4/ForSale/...cer.shtml#FAQ1
Old 02-04-2024, 01:42 PM
  #30
Khan3vzhilux's Avatar
1992 ifs ball joint spacers
Originally Posted by 94exblack
I keep reading on here everyones ifs truck has a 1 inch or 1 1/2 in ball joint spacer. I may be wrong but that sounds like a very bad idea to me. Anyone have any good or bad experience with using a spacer.
I have installed my 1992 hilux with ifs suspension.
I had some camber issues bt I sort it out.
it is working bt I have an issue when i engage the 4wd(hi and low) bt i have to check the suspension.
chuckr
09-29-2012 09:48 PM
surferkid26
11-18-2009 07:43 PM
8yota9
01-24-2007 05:43 AM
BS Industries
07-26-2006 01:07 PM
Quick Reply: ball joint spacers is this really a good idea
