B-pillar exterior plastic trim removal?
Old 02-16-2006, 10:33 AM
InternetRoadkill's Avatar
How does the black plastic trim which is on the B-pillar (the pillar just behind the front door) come off? I've looked all over for a screw or snap to get that off, but I haven't found a way to remove it without breaking something. I need to repair the air vent flapper valve which hides under it.
Old 02-16-2006, 10:39 AM
celica's Avatar
There is a valve under it????
Old 02-16-2006, 11:18 AM
Yes. It's just a simple reed valve that allows air to escape to the outside, but not back in. Most cars have this thing hidden somewhere.
Old 02-16-2006, 11:38 AM
celica's Avatar
I thought on the runner it was in the back behind the back cargo glass. Is this in addition to it?
Oh - wait, what year are we talking about? I was thinking 2nd gen.
Sorry - now I know what you are talking about - 1st gen or the pick of the same design. I believe it is held on with spriong clips, but to be sure cal the dealer and ask them. They have an exploded view of it on their system that shows the style of attachment
Old 02-16-2006, 02:32 PM
I forget this forum covers both 1st and 2nd gen. The piece in question is on an 88 (1st gen).
Old 12-08-2011, 02:53 PM
MrArmyAnt's Avatar
Bump?
Old 12-08-2011, 03:19 PM
slacker's Avatar
there is only 1 way to do it .
first push the bottom forward to unlock the lower clip . Then up to unlock the 2 upper clips , then down to unlock the 2 center clips .
Problem is , after the sail panel is removed there is no way to get the clips out successfully , and you wont be able to reinstall the sail panel with out the clips in it
I just replace the clips http://www.toyotafiberglass.com/4Runner.htm
Old 03-22-2017, 07:55 PM
4runnerSolitude's Avatar
Hey I cant add the sail panel clips from that website , any help ?
Old 03-22-2017, 09:16 PM
Nervo19's Avatar
Part numbers are here in post # 27 https://www.yotatech.com/forums/f199...00/index2.html
westonian18
05-01-2020 06:38 AM
rusty904
03-27-2017 05:20 PM
mussy01
12-13-2016 08:20 PM
lledwod
08-30-2016 01:03 PM
58rennur4
08-04-2015 08:49 AM
Quick Reply: B-pillar exterior plastic trim removal?
