Auto to manual swap
Old 02-16-2010, 12:13 AM
SpecialScottie's Avatar
Auto to manual swap
So Im getting ready to swap my 85 over from auto to a manual transmission. I found a w56 (I believe to be a C) at the junk yard in a 91 pickup. Although it has the forward shift T-case. Would I still be able to use it as 85-88 used top shift t cases?
Old 02-16-2010, 12:33 AM
malteserunner's Avatar
I have a 95 tranny/t-case in my 87. You shouldn't have any problems. I did have to trim the hole in my floorboard to clear the shifters, as they are a little farther forward than my original shifters. Good luck with your project.
Old 02-16-2010, 12:35 AM
Did you need to get different shift boots or change the interior pieces?
Thanks
Old 02-16-2010, 12:43 AM
My 4Runner was missing the original trim around the shifters, and the boots were in bad shape, so I built a custom cover for the tunnel, and used an ammo can for the console. It's actually still a work in progress, since I haven't added the cupholders yet.....doh. It will be done soon, however.
Old 02-16-2010, 12:49 AM
Got any pictures?
So if I did this swap I would probably need the boots and trim piece from the 91 correct?
Old 02-16-2010, 12:52 AM
Originally Posted by SpecialScottie
Got any pictures?
No pics yet. I will add them to my thread when I finish the cupholders next week.
I'd say using the trim and boots from the 91 would be easy enough for your swap.
Old 02-16-2010, 12:54 AM
Right on. Thanks alot for your help
Old 02-16-2010, 01:05 AM
Any time.
Old 02-20-2010, 08:37 PM
tonyusmc27's Avatar
Let me know how your build up goes I just picked up a 89 W-56 foward shift today will be doing the same.
Old 02-20-2010, 08:49 PM
What do you plan on putting it in?
Old 02-20-2010, 09:50 PM
tonyusmc27's Avatar
85 4runner as well
Old 02-20-2010, 09:54 PM
tonyusmc27's Avatar
I got engine and tranny from 89 with 111,000 miles. snaged crossover from manual heard crossover from auto won't work and about everything to do the swap ie clutch pedal, slave cyclinder got a pretty good deal on all of it. Cant wait to start maybe we can learn from each other this will be my first major project.
Old 02-20-2010, 11:49 PM
Mine came out of a 91. Not sure how many miles. Are you talking about the crossmember? From what Ive read, the crossmember itself is the same but the rubber mount is different. Im doing dual cases at the same time
Old 02-21-2010, 08:05 AM
tonyusmc27's Avatar
Yes crossmember. Well good luck let me know how the dual cases go when do you plan on starting?
Old 02-22-2010, 09:46 AM
Well marlin has a sale on the dual case adapter so it might be sooner than I expcted
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
88sasturbotoy
08-11-2015 01:56 AM
deepmarsh
08-06-2015 03:44 AM
KBar
07-13-2015 06:01 PM
Tyler Cunningham
07-11-2015 10:18 AM
Quick Reply: Auto to manual swap
