Auto to Manual 5sp swap - Complete!
Old 07-13-2016, 11:33 PM
  #61
wyoming9's Avatar
Pretty hard to figure out when you don`t say what your working on and what year your donor was !!
Old 07-14-2016, 09:43 AM
  #62
julius415's Avatar
Sorry still figuring out what I had, did more research last night. So body is for 94 v6, engine donor seems like a 89/90. The reason I say this is because the engine to body connectors are different. Doing some research I found put that the connectors on body side are called ih1 and ih2, and I found pin configuration on another thread. The connectors on engine side are different and are called c1 and c2 (it's a older style less pins). I found pin configurations for c1 in another thread, but no luck with c2 so far. I was hoping to find it rather than having to download ewd from tis but might just have to
Old 08-12-2016, 06:36 AM
  #63
coffey50's Avatar
I just finished up this swap myself. Went to reverse out of my garage and the clutch was slipping so badly it smoked a little. I shut her down and let it cool off. Any ideas on why the clutch is slipping. All OEM Aisin Master, slave, clutch, flywheel, pressure plate. I bled the system. I've read the pedal can be adjusted and that effects the clutch engagement. I messed with the pushrod and now the clutch won't grab at all. Any help would be dearly appreciated.
06-01-2021 01:51 PM
icentropy
09-16-2020 02:47 PM
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
jon.r
07-11-2015 03:34 PM
ItsJustD
07-07-2015 07:49 AM
Quick Reply: Auto to Manual 5sp swap - Complete!
