ATTN: 1st gen 4Runner owners.
Old 01-19-2009, 06:10 PM
x-man's Avatar
How many of you have this problem? I had the bolt the other way and it kept on rubbing the tank till it hit the seal, just my luck it broke the seal on the trail!
This is my 2nd tank...and yes I know my spring is bending backwards.
Old 01-19-2009, 06:31 PM
abecedarian's Avatar
haven't had that problem
Old 01-19-2009, 06:34 PM
corax's Avatar
can't say I've ever had that problem, and my springs are flat
Old 01-19-2009, 06:40 PM
I was gonna say that even with 4" blocks in the rear I didn't hit the tank even though the springs were twisted up and high on the front side of the axle.
Old 01-19-2009, 06:41 PM
87LVRunner's Avatar
Nopers...
In an accident? Bent gas tank mounts?
Old 01-19-2009, 06:46 PM
Kiroshu's Avatar
Dunno if thats a prob for them much but judging the look of your spring there i think its "your" problem.
Old 01-19-2009, 06:51 PM
waskillywabbit's Avatar
You got a twisted frame, bent spring or your gas tank has been smashified to somewhere it wasn't when installed.
It ain't supposed to do dat.
Old 01-19-2009, 07:46 PM
874runnersr5's Avatar
Never seen that happen
Old 01-19-2009, 07:51 PM
x-man's Avatar
My 4Runner has never gotten into a accident, on the other side of the tank my Drive shaft hits it at full flex. Might be the springs all crapped out already.
Old 01-19-2009, 08:26 PM
Take some differnt shots/angles
Old 01-19-2009, 08:53 PM
x-man's Avatar
If I remember tomorrow after work I will.
Old 01-19-2009, 11:11 PM
85TurboRunner's Avatar
I had the same thing happen a few months ago but it wasn't as bad as yours. I fixed it with JB weld and haven't had any issues since. I also reversed that bolt so the head is on the tank side and doesn't stick out as far.
Old 01-20-2009, 08:58 AM
scuba's Avatar
I would say you have a bent frame, or you have some problems with the axle moving wayy to much, get some new damn springs. And it hat doesnt fix it, get a new truck...
Old 01-20-2009, 09:12 AM
Volcom's Avatar
My TG 4" springs the same thing. It hasn't damaged the tank yet but it might one of these days. My driveshaft rubs on the tank skid plate on the other side big time as well
Old 01-20-2009, 08:16 PM
muddpigg's Avatar
My 4" allpro's do the rubbing thing, too. After your experience seems I better grind the bolt end down. Thanks for the 411.
Old 01-21-2009, 11:09 PM
mnmontana's Avatar
never had that issue, but I got helper springs on.
06-01-2021 01:51 PM
mskalmus
05-28-2017 07:51 AM
coryc85
07-06-2015 04:07 AM
HRDC0R19
07-05-2015 06:43 PM
CJ94yota
07-03-2015 10:14 PM
Quick Reply: ATTN: 1st gen 4Runner owners.
