APR head stud help 3.0 3vze
Old 01-09-2008, 12:05 PM
mrnick1979's Avatar
i called ARP for a price on head studs for a 3vze but they said they didnt have a kit. he said if i could give him the pitch, size, length, and diameter that he could cross reference them or make some up. does anyone have any helpful info on these studs. i would prefer ARP studs instead of bolts. thanks for any help.
Old 01-10-2008, 08:55 AM
ewong's Avatar
go buy ONE bolt and sent it to ARP?
Call LC Engineering and see what they have?
Be aware that ARP head studsa re 3x-4x the cost of head bolts.
ALso on the 22RE - studs make it harder to R&R hte head hwen its in the engine bay (AFAIRC).
May be less of an issue on the V6
Old 01-10-2008, 01:46 PM
mrnick1979's Avatar
arp has studs in stock
talked with arp, the stud is a 11x1.25, studs ,washers, and 12pt nuts total up to be $191.68 for the set. part number for the studs are (ATP5.200-1lb) the stud is 5.2 inches long threaded 11x1.25 on block side and 7/16x20 on the nut side.
Old 07-30-2008, 08:33 AM
FJoel's Avatar
Anybody have these installed? Why don't they list them in the catalog? (I just checked again...)
Is it because they are 7/16x20 on the nut side? I'd prefer they were metric too, but they could atleast list them!
Old 08-22-2008, 06:35 PM
FJoel's Avatar
Well I ordered them and received them. Hardcore. Expensive, but hardcore.
These babies and the Rock gaskets from engnbldr should hold that head down under 7PSI of forced induction.
Old 07-07-2012, 12:16 AM
Asuarez737's Avatar
Quick question. Since the thread pitch is standard and not metric, wouldn't that be a problem since toyotas are metric? Sorry for reviving the post but I myself NEED the arp bolts/studs for my heads. Thanks
Old 07-07-2012, 12:23 AM
abecedarian's Avatar
11x1.25 is 11mm diameter with 1.25 threads per mm. That is metric on the engine side.
SAE standard on the nut side is irrelevant if you have the proper nuts to install
make sense?
they have metric threads on one end to thread into the block and standard threads onthe other end to clamp the head under nuts.
Old 07-07-2012, 01:32 AM
strykersd's Avatar
I wish I saw this a week ago! ARP head studs were a pain to install in my 22re!
Old 07-07-2012, 11:12 AM
Asuarez737's Avatar
make sense?
yeah i understand you now! so the part number thats given, is for these type of studs, and they will work on the 3vz-e?
Old 04-12-2017, 10:53 AM
stefanc's Avatar
@FJoel Apologizing for resurrecting the thread, but I was wondering how the studs were holding up and if its worth the investment?
Anyone please feel free to chime in if you have any opinions.
Thanks!
Old 04-12-2017, 04:44 PM
space-junk's Avatar
he hasnt been active here fore a few years.
Old 04-12-2017, 06:31 PM
stefanc's Avatar
Figured it would be worth a shot, trying to get some feedback on these studs versus the standard head bolts
Old 04-13-2017, 05:18 PM
space-junk's Avatar
ARP head studs are always worth the investment if youre building a hotrod. if youre building a standard motor, well, toyota over-engineers most parts. you will be fine with stock.
kgcwb44
01-29-2023 10:02 AM
Gone Fission
07-24-2015 12:49 PM
whereAreMyPants
07-22-2015 03:32 AM
smiley52
07-11-2015 05:16 AM
Coreyr384
07-10-2015 11:13 AM
Quick Reply: APR head stud help 3.0 3vze
