any way to make the center bore on rim bigger?
Old 03-20-2009, 08:31 AM
93toyrunner's Avatar
i just picked up a set of 33x9.50R15 tires on a set of old chevy steel rally rims kind of like the rims 302yota has and I wanted to know the easiest way to make the center bore bigger of make the wheel fit with out having to buy new rims any suggestions?
Old 03-20-2009, 08:36 AM
scuba's Avatar
Any Machine shop can do it...
Old 03-20-2009, 08:52 AM
TOYOTA 1's Avatar
a die grinder will work wonders.
Old 03-20-2009, 09:00 AM
the problem with a machine shop is i do not want to have to dismount the freshly balanced tires
and with the die grinder i thought that would take too long
Old 03-20-2009, 09:08 AM
TOYOTA 1's Avatar
well its not gonna be fast lol, but shouldn't take forever
maybe few hours to do all 4..
you could use a torch, or a plasma cutter. but i don't know if the heat will mess up the strength of the wheel?
Old 03-20-2009, 09:23 AM
Dublin's Avatar
Haven't done it in a while and then it was an aluminum rim, but a cup saw works great. You need to bolt a piece of wood to the back side of the rim using the bolt holes so the pilot bit has a way of starting and staying centered. It takes a couple minutes per rim and no need to remove the tire.
Old 03-20-2009, 09:25 AM
desertcox05's Avatar
die grinder with about 6 rotory files. try to find something where you can turn the wheel while you hold the d/g still. that way you'll have a consistant finish
Old 03-20-2009, 01:09 PM
Varv's Avatar
If you can find a machine shop with a decent size mill they can bore the center without taking the tire off the rim.
But I cant see it taking to long with a die grinder if you had to do it that way.
Old 03-20-2009, 01:32 PM
abecedarian's Avatar
Use an engine cylinder honing tool or ridge-reamer?
(actually, that should keep the hole round too)
Old 03-20-2009, 01:36 PM
thats a good idea too abe.
Old 03-20-2009, 02:45 PM
thanks guys great ideas i will have to try a few
chukarhunt
12-08-2019 11:39 AM
09-04-2015 09:27 AM
terminator
07-27-2015 07:13 PM
Yotoder865
07-09-2015 07:51 PM
akaphilly
07-09-2015 02:34 PM
Quick Reply: any way to make the center bore on rim bigger?
