any tips on doing a lower intake on a EFI 22RE?
Old 02-19-2007, 05:43 AM
skife's Avatar
i just got the lower intake off last night, PITA to get to some of the bolts, but i got to 'em.
i got the new gaskets, should i seal them with black RTV?
Old 02-19-2007, 05:49 AM
rdlsz24's Avatar
I have heard people say yeah use RTV on gaskets and no don't use it. Personally I didn't use it on anything that already had a gasket when doing my head gasket replacement a couple months ago.
Rob
Old 02-19-2007, 07:07 AM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Rob
x2..on that.
Old 02-19-2007, 08:18 AM
all_terrain17's Avatar
I had a massive vacuum leak whenever I failed to use RTV on the lower intake to head gasket. Mechanic sealed it up with black RTV and that seemed to do the trick.
Old 02-19-2007, 08:35 AM
design311's Avatar
I always use a very very small amount of RTV on most all gasket surfaces. Usually put a light coat on the gasket with my finger. Just my 2 pennies.
Old 02-19-2007, 04:41 PM
Targetnut's Avatar
RTV is not good for fiber gaskets.
It acts like a lubricant and can actually cause a gasket to squeeze out of position. Get Permatex spray gasket adhesive. spray both sides of the gasket and allow it to "tack up" this will provide sealant and help hold things in place during assembly
Old 02-19-2007, 06:13 PM
design311's Avatar
If you put a small amount of RTV on a gasket and let it set up it will not "lubricate" the gasket at all. The 20-25 small block chevys and 3 22r engine rebuilds I have done have all had RTV used on gasket mating surfaces where I felt I needed a litte more than just the gasket to secure a tight fit. I wouldn't think twice about using it.
Old 02-19-2007, 06:49 PM
skife's Avatar
i used a small amout of RTV on the gasket.
Doug4320
03-24-2018 10:11 PM
RatOmeter
10-22-2015 03:17 PM
rondogracing
Engine Swaps
16
08-24-2015 03:02 AM
1994toyota
07-17-2015 03:03 AM
Sandman
07-14-2015 12:36 PM
Quick Reply: any tips on doing a lower intake on a EFI 22RE?
