Are all 86-95 frames the same?
Old 02-25-2008, 05:27 PM
James Dean's Avatar
90-95 trucks and 4Runners look like this with the valance off. The outside holes have cup shaped absorbers mounted in them.
Old 02-25-2008, 05:32 PM
Vanman's Avatar
Here are two pics. It looks like your hitch is a bit more serious...
The WARN hitch WAS specified for a 1991 4Runner 4x4, so I hope everything is OK.
Old 02-25-2008, 06:44 PM
notanymore's Avatar
Originally Posted by MonsterMaxx
If I were you I wouldn't attach a bumper that you are going to yank on that way.
<--having personally ripped a bumper off my friends truck which was attached that way.
Also, if you are considering mass production you need to consider that this area often suffers damage due to it's flimsyness and body shops never really put it back to stock.
There are some nice mounting locations on the side of the frame, though you either need to cut the body mounts off and attach them to your bumper or hook around them. From your photos you could easily tie into the tow hook bolt locations.
If you do it like I did on mine, when some dumb blows a redlight and hits you head on, your bumper will stay on the truck and protect it.
Dip in the Chevy ran the redlight and took me just about head on. He went to the hospital, his truck went to the bone yard, the GF and I went to dinner in my Truck.
that makes me want a new front bumper lol
but back on topic, i have the bottom holes, but i cant remember if they are threaded or not and i would have to look andsee if i have the front ones, but im pretty sure i have them.
Old 02-25-2008, 07:27 PM
Matt16's Avatar
Where is that idler arm from, I haven't ever seen on like that on a Toyota before.
Old 02-25-2008, 07:32 PM
  #25
toytech76's Avatar
That looks like a MOOG idler arm. Much more heavy duty than the stockers
  #26
4Crawler's Avatar
Originally Posted by hmmwv15
If it's any consolation, my 87 p/u didn't have those holes threaded.
Yep, the '86-'89 4Runner and '86-'88 pickups have their front bumper bracket holes up on the front of the frame. One hole in the frame and another one a few inches above the frame. So that will be different than on the later ones where the bumper bracket holes are on the side of the frame.
Old 02-25-2008, 07:46 PM
  #27
Jay351's Avatar
Just for clarifcation - Those impact cups did not appear on the trucks or 4runners till about 93 or so.
Also the moog idler arm (what I run ) are not stronger then stock
Old 02-25-2008, 07:57 PM
  #28
James Dean's Avatar
Thanks, I guess the ones I've seen them on are 93-5. I think that was when they were required to make the bumpers speed rated, and the lower valance didn't cut it on it's own.
Old 02-25-2008, 08:11 PM
  #29
Jay351's Avatar
It had something to do with front end impact IIRC. I remember there was a thread about it awhile back, for the life of me I can't remember the title.
Old 02-26-2008, 08:48 AM
  #30
MonsterMaxx's Avatar
Originally Posted by James Dean
It's the same locations all the other companies use...
yup, and I've seen many an aftermarket bumper laying on the ground after just being ripped off the truck (and the way they come off it usually takes some good stuff with it for a little extra damage.)
Tied into the tow hook bolts, this person's design is pretty solid looking. If it were me, I'd take your design and add two straps that go between the tow hooks and the frame (with longer bolts) and then gusset that strap really well.
Looking at that prerunner bumper I like the way they tie on the outside of the body mount, Any time you can get some triangulation or separation between bolt holes that's a good thing.
FWIW: I've had a '91 and now a '94, neither of them had the 'cups' on the front cross member. It might be a region thing, Toyota makes all kinds of weird changes from one region to another. My '91 was a Northeast and the '94 is a Southeast. I wonder if that could have something to do with California models.
You may also want to consider the inherent weakness in the Toy frame when designing your bumper.
The front horns can get bent (mine did a little), and you should absolutely add the 4th crossmember to the front suspension (avail from a wide variety of sources.) This greatly strengthens the frame behind the front wheels. If I had it to do over again, I'd run some kickers down to the front axle (eliminate the skid) and make my own skid.
Old 02-26-2008, 04:04 PM
  #31
Vanman's Avatar
I am new to this stuff. What is an idler arm? I have not done anything to the 4Runner. Well, I shouldn't say "anything," 'cause tires, brakes jobs, tuneups, etc. do add up. Just no "mods." By the way, I am assuming you are talking about this last picture.
Thanks.
Old 02-26-2008, 04:07 PM
  #32
Jay351's Avatar
Take a peek at the picture above - see the rusty bracket bolted to the frame, that has an arm on the end bolting to the center link? Thats the idler arm (aftermarket one).
Old 12-11-2017, 05:38 PM
  #33
ToolTyme1's Avatar
Do you make that same front receiver hitch for an 84 Toy?
Old 12-12-2017, 03:58 AM
  #34
wyoming9's Avatar
Red face
9 Year old Thread I don`t recall seeing them around for sometime
Maybe a PM might get there attention
kawazx636
10-06-2021 03:03 PM
ladybugRC
458
08-21-2020 10:41 AM
RDubya
02-10-2017 04:46 PM
live4soccer7
05-11-2016 06:52 PM
myotherrideisayoshi
09-29-2015 05:41 AM
Quick Reply: Are all 86-95 frames the same?
