Old 02-10-2016, 09:26 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering & Suspension Guides
Print Wikipost
Aisin Locking Hubs Tear Down/Build Up
Old 08-08-2012, 01:17 PM
  #61
space-junk's Avatar
Both of those look fine...
Maybe some better pics?
It should be fine to run it without the hubs as log as you have ADD plates installed... Otherwise, no... Don't drive it without hubs...
Old 08-10-2012, 01:24 PM
  #62
ChefYota4x4's Avatar
Well Troy...... YOU ROCK, "Pops!" hahaah.....
Great write up! I'm doing mine, .... but they'll go on AUTO LOCKING HUBS, not ADD.... So I'ma have to cross this with another good thread to make sure I cover all the steps....
BUT SERIOUSLY.... As I took mine apart, they had been flipped(the spring and pawl were turned over and actually inside the clutch area.... As I took it apart, ..... I realized how freakin filthy they were(full of hay, etc., lol)... So I cleaned em up fairly well... Gonna use this as a guide of what to do/what not to do(via the tips therein of people learning the hard way) and posting this link on my build, FO SHO!
Thanks for doing that(eons ago, lol)...and for continuing to check in(and for making it a THREAD, not a write up with comments disabled )
Best wishes to ya, Space Poppi!
PS> Mine, inside, were REALLY OVERGREASED, ... .not only that, they had a compromised start gasket on one side and the bearing missing.. SO I used ROT's trick and VOILA! Missing bearing ball replaced! (Credit to rustEd, he told me that ROT had done this).... I'm going to soak the clutch/pawl and larger spring(they have the most rust, only rust really) in some parts cleaner for a while... Then Come back to slap em together in a few days when I have the CV's rebooted, one rotor replaced with lifetime warranty and so on....(IOW, when I'm ready to go)...and then I'll use this, FOR SURE, to help get em ready for assembly/install. (I WILL NOT use too much grease, ... read every post.)
My before and afters don't show how bad they were inside... FULL OF hay, RTV chunks, etc. But they seem to roll fine/smoothly... Just curious if you think I need to pull the whole hub apart...(Left the spline/roller section in)>> they seem to be clean.....but I think in using so much parts cleaner to flush em I've left the lower most stuff's dryer than they should be? >>>>
Before...
After.....
Old 08-10-2012, 01:27 PM
  #63
PS> Off to pick up the ordered days ago O-rings and Cover Gaskets...
Thanks again, Troy... And best wishes man!
Old 08-10-2012, 03:50 PM
  #64
paynemw's Avatar
awesome write up... can't wait to get a set for my rear full float kit
Old 09-08-2012, 11:14 PM
  #65
space-junk's Avatar
Chef, thats a GREAT idea using the bottles as a paint stand! i made the mistake of using the foam crap that is used to pack large objects like TVs... yea, just an FYI, that crap melts and smells bad... LMAO! lessons learned when i was "young" hehehe...
thanks for the comments guys! i appreciate it...
hard to believe that this was the FIRST mod that i ever did to my first toyota... seems so long ago... haha... and i STILL need to do this to my Tacoma... thinking of going black for the ring and white for the dial face... since i have white wheels and whatnot...
Old 01-11-2013, 02:58 AM
  #66
92 TOY's Avatar
YES!
this looks totally do-able for me and Joe!
gotta inventory and see if we are missing parts. and there is a rebuild kit for this, no?
Old 01-11-2013, 04:21 AM
  #67
waskillywabbit's Avatar
Several helpful links
http://www.se4rj.com/forum/showthread.php?t=293
http://www.se4rj.com/forum/forumdisplay.php?f=19
No rebuild kits per se but lots of replacement parts available
:wabbit2:
Old 01-11-2013, 05:12 AM
  #68
92 TOY's Avatar
:wabbit2:
tanx...very good stuff rot thar
Old 01-11-2013, 05:36 AM
  #69
Excellent timing on this , I have some aisin hubs to replace the warn hubs on my 4RNR
Old 01-20-2013, 07:02 AM
  #70
JohnnyCanuck's Avatar
beauty! I have some donor hubs on a parts truck I just bought, out with add and in with these. I'm going to powder coat per wabbits suggestion, hopefully my wife likes the smell of cooking hubs in the oven.
Old 07-13-2013, 09:40 PM
  #71
'85 Yota's Avatar
Rebuilt mine today thanks to this thread!
Old 01-06-2014, 05:39 PM
  #72
PUNK_AND_GOTH's Avatar
jw will this work on a t100? sorry i found this surfing TN and is it easy as the pics say and can i use warn hubs ?
Old 01-06-2014, 07:40 PM
  #73
T100 hubs are the same, warn hubs don't use cone washers they have dowel pins, I prefer the asins but it's personal preference. Aisin are easy to rebuild, they don't stick out as far as warns, they have less turning radius to lock in than warns. You can find a used set of aisins for under $100, cheap to rebuild.
Old 05-27-2015, 10:35 PM
  #74
gtct10b's Avatar
AWESOME write up ladies and Gents, now I have something else to look forward to doing once I change my CV's out. I may as well do it then than do it later, rofl.
Old 05-27-2015, 10:47 PM
  #75
gtct10b's Avatar
well done to all of ya and its gave me some great ides also!!!!!
Old 12-08-2016, 12:08 AM
  #76
space-junk's Avatar
Necro ing this thread as a reminder that I need to rebuild the new set on the runner.
Old 05-18-2017, 12:33 PM
  #77
MaK92-4RnR's Avatar
And the set I gotcha. lol
Old 10-17-2017, 06:43 AM
  #78
Magic Hat's Avatar
Is the spline count the same for 1989 and 1990? I have 1990 3.0 with ADD and the Pick a Part lot has a 1989 with 3.0 and Aisin Manual Hubs. I think they're about $35 each, and if they'll fit, I may have to grab em up. If I do, this excellent write up will be very helpful. Thanks to the OP!!
Old 10-18-2017, 12:14 PM
  #79
space-junk's Avatar
you're welcome!!
Old 03-16-2018, 04:02 PM
  #80
mkivbren's Avatar
Anyone know the the finish of the hub body? I'm thinking forged alum. Anodized? Thinking of polishing then clear coating.
Quick Reply: Aisin Locking Hubs Tear Down/Build Up
