air cleaner and smog help
Old 11-26-2008, 01:27 PM
parkkicks's Avatar
Question air cleaner and smog help
hey all. i want to put an aftermarket aircleaner on my 87 22r. my truck still needs to pass emissions untill it is 25 years old. is there anything i should know about putting a new one on smog wise? will i have to remove anything that is necessary to pass emissions?
thanks a bunch
Parker
Old 11-26-2008, 10:36 PM
space-junk's Avatar
i dont think that you will pass a visual test if you dont have your stock air box...
Old 11-27-2008, 08:39 PM
parkkicks's Avatar
do u know why this would be? i dont think i understand why they would not let me have something that would improve airflow therefore improving fuel economy and therefore reduce emissions... from what i understand the stock airbox is very restrictive and should be removed immediately.
thanks anyway
Parker
Old 11-27-2008, 08:49 PM
abecedarian's Avatar
Depending on the parts, may or may not be of a problem... may cause an argument though.... If the parts you install have C.A.R.B. exemption orders, they have no other choice but to allow them since there are two basic standards- Federal and California, and since California standards are more strict than Federal, and states have the option of adopting California emissions standards or following Federal standards, California standards are acceptable in lieu of Federal standards. However, if the system does not meet the basic Federal standards, you are S.O.L.
Old 11-27-2008, 09:39 PM
parkkicks's Avatar
thanks abe. so i would really appreciate it if anyone could point me in the right direction on an air cleaner assembly. oh and if i use the stock aisin carb is it necessary to get the lcengineering adaptor? or will a standard 2 bbl cleaner work?
thanks a bunch
Parker
Old 11-27-2008, 11:01 PM
/me lolz. I pointed you in the right direction. If you can't do it, then fine.
Use the stock aisin carb, use the stock air filter housing and PCV connections for your emissions tests, then go do whatever you want.
Old 11-28-2008, 04:18 AM
gte718p's Avatar
Results may very, but I passed a gold shield station (after being labeled a gross polluter) without an air box and with one of those cheap ricer high flow wantabe cone filters.
Tacoma1313
08-17-2015 05:44 PM
cr@ves4wheelin
3.4 Swaps
08-17-2015 07:47 AM
Ryan_a118
08-12-2015 12:57 PM
accuracy
08-04-2015 08:05 PM
timmJ
07-07-2015 02:01 PM
Quick Reply: air cleaner and smog help
