aftermarket cam, valve adjustment?
Old 09-29-2010, 07:34 PM
SDHNTR's Avatar
I'm looking at buying an 86 4Runner 4x4 with 22RE and 5 spd. The previous owner installed an aftermarket cam when he had the motor rebuilt. I'm fine with that, but what do I do if/when the valves need adjustment? How would I find out the proper clearance specs? Of course the current owner does not know the make of the cam.
Old 09-29-2010, 08:03 PM
iamsuperbleeder's Avatar
it would be best to know the manufacturer of the cam
if I remember correctly, engnbldr recommends .07 and .11 with his
Old 09-30-2010, 02:05 AM
TinMan's Avatar
Before an adjustment, check and see what they are adjusted at. intake and exhaust hot. Then average them out.
LCE cams are adjusted to factory specs.
Enbldr is .007/.009
Comp cams and many others are listed on their sites.
later
Old 10-02-2010, 01:37 PM
muddpigg's Avatar
Delta Cams calls for cold adjustment, don't remember numbers.
Old 10-02-2010, 02:14 PM
drew303's Avatar
I have Delta can just set to factory spec. If its not making noise at factory I don't worry about it. More importantly advance your timing if you want to gain benefit from the can!
I'm 22r with 260 at 12 deg works great!
Old 10-02-2010, 02:17 PM
drew303's Avatar
Cam LOL I'm on my phone ;p
Blamalam
03-12-2022 07:34 AM
09-04-2015 09:27 AM
Dennisx2
08-10-2015 06:48 AM
yourrealdad
07-21-2015 11:13 AM
razorman8669
07-12-2015 12:13 PM
Quick Reply: aftermarket cam, valve adjustment?
