ADD (Automatic Differential Disconnect) is NOT Auto Hubs - Explanation and Details
Old 10-07-2011, 04:30 AM
waskillywabbit's Avatar
Talking ADD (Automatic Differential Disconnect) is NOT Auto Hubs - Explanation and Details
REmoved
Old 10-16-2011, 01:42 AM
dubbsbetty's Avatar
Good deal Waskilly! I will like to add however that one should really never shift on the fly while moving any speed past 0 mph or bad sounds/ binding occurs. I have em on my 2nd gen runner and is a no good! I know that most texts say it's a "shift on-the-fly" system but the actual moaner's manual says to put the vehicle in neutral with the brake depressed before attempting to engage the transfer case into gear. It is nice not having to reverse out of gear tho!!
Old 11-01-2013, 09:41 PM
nuttynu's Avatar
What's happen?!!!
Old 11-03-2013, 09:17 AM
lobukbuild's Avatar
i do not understand this thread. whats the question? add differentials lock or unlock inside the axle housing in the middle beside the third member via a vacumm controlled fork. these axles have permantly locked hubs. manually locking hubs are just that, manual, and lock and unlock by hand at each hub. transfer cases can be shifted on the fly from 2wd to 4wd hi as long as your axle is locked and moving at the same speed as the rear axle, but not from 4wd hi to 4wd lo. you will need to be at a complete stop or darn close to it.
Old 11-03-2013, 09:24 AM
HighLux's Avatar
He posted informative tech. But he got banned for being a bad vendor. He vengefully removed every post that was helpful in retaliation.
Old 11-03-2013, 10:13 AM
93Xtra-Cab's Avatar
So that's what happened...I knew he left and a lot of his posts were deleted, but I never knew the whole story. Shame he had to go out that way...
Case closed
Old 02-28-2014, 10:34 AM
cjohnson's Avatar
Is there a copy of this info in another thread?
Old 03-01-2014, 07:32 AM
wyoming9's Avatar
Red face
Just what do you need to Know?
ADD is one thing
Automatic Hubs Quite another thing myself i think one of Toyota`s poorer ideas.
Old 03-03-2014, 06:24 AM
cjohnson's Avatar
Nothing specific, just wanted to learn about the ADD system
Old 03-03-2014, 07:12 AM
RJR
RJR's Avatar
This link
http://www.off-road.com/trucks-4x4/t...tem-19259.html
I found that by typing "toyota add" into Google. 1st link shown...
Old 03-03-2014, 07:24 AM
cjohnson's Avatar
Thanks RJR, I've read that page before, was just wondering if anyone had copied this specific thread over somewhere. Mainly curious if it had additional info (the wayback machine didn't have a copy).
PS. Gonna try following your "3vze Intake Plenum and Upper Engine Cleaning and TuneUp" thread this weekend!
coreyedwards7611
01-16-2016 06:38 PM
Ladythump
22
11-09-2015 08:53 AM
jerusry
10-19-2015 05:28 PM
deepmarsh
08-06-2015 03:44 AM
Steven.m.paulk
07-13-2015 01:40 PM
Quick Reply: ADD (Automatic Differential Disconnect) is NOT Auto Hubs - Explanation and Details
