The AC fan
The AC fan
Ok so my frickin AC fan keeps turning on intermittently (the electric fan in front of the radiator, behind the grille).
It just turns on, and goes off. Its just buggin me more than anything.
I've taken the AC pulley belt out, because I really dont use AC.
I'm guessing its some kind of electrical problem. Is there a fuse I can pull to remove power to the AC fan, if so where is it? Otherwise, how do I remove it and deal with the wiring harness for it in a proper way?
The fan gets power through a fusible link, and it's hot all the time. Sounds like there's a broken wire or something on the ground side. There may be a plug on the wires near the fan that you can disconnect, or try remoying the fan control relays. They should be on a relay block near the main fuse panel under the hood. In the wiring diagram they're labelled A/C Condenser Fan Relay #1 and #2.
kawazx636
10-06-2021 03:03 PM
runnermedic
13
09-21-2015 05:20 PM
