A340F delayed 1-2 shift when cold??
Old 04-21-2009, 07:08 AM
davefarr's Avatar
I've had the 1990 4runner 22re long enough to catch up on most items the previous owner neglected- but not long enough to know these trucks well. I have a delayed 1-2 shift when cold but when operating temp seems to shift fine- checked oil level and TV adjustment OK. Delayed shift under light throttle but will shift when let off throttle. 131k miles.
A couple other questions:
Is it normal for pressure to blow off when opening fuel cap for a fill up? I would have thought any vapors would be pulled through the engine for emissions.
Transfer case lube- I replaced what was in there- ATF with ATF but further reading suggests gear oil???
Old 04-21-2009, 11:06 AM
InternetRoadkill's Avatar
Bad shifting when cold is usually the shift solenoids sticking. Don't use gear oil in the 340 transfer case. The tranny and xfer case share the fluid.
Old 04-22-2009, 09:48 AM
davefarr's Avatar
Phoned back home to a tranny shop, buddies first guess was ATF as well but I asked him to spec it. A340H takes ATF, A340F as in 22RE takes gear oil- separate transfer case.
Old 04-22-2009, 10:54 AM
Didn't know that. This brings up the question as to whether the xfer case has a shift solenoid in it like the 340H does.
Old 04-22-2009, 02:29 PM
davefarr's Avatar
Good question- mines manually shifted.
Daenerysdad
10-01-2015 07:33 PM
LotOMiles
09-14-2015 11:45 PM
--Oz--
09-06-2015 01:06 AM
moparbay
09-03-2015 12:48 PM
Nick Berg
09-03-2015 04:36 AM
Quick Reply: A340F delayed 1-2 shift when cold??
