96 3.4 swap into 90 4Runner q's. S/C?
Well, I have been looking around and found some more info. Just like you said, the fuel system cannot keep up. too small a pump, and too small injectors. Also, the computer wont do the timing right, or put enough fuel to the engine.
With the S/C install, the URD kit will make it all work. Comes with bigger injectors, bigger fuel pump, plugs, thermostat, and another ECU to work with the stock one. Sounds like the way i will go when i start this install.
rockota
12-18-2006 05:18 AM
Cougarfreak
10-17-2004 04:24 AM
Los Gatos?
02-20-2003 03:24 PM
