95 won't fire up.
Old 01-06-2013, 03:27 PM
dakotawho's Avatar
Use that video on the distributor....its too easy to not check!!!
Old 01-06-2013, 03:37 PM
Jackedupjoe's Avatar
I did try that video and all check good, was a 1 on tdc compression stroke. Two wires were wrong got those fixed and still nothing,
Old 01-06-2013, 03:45 PM
dakotawho's Avatar
least it rules that out then. 22r or 22re?
Old 01-06-2013, 03:51 PM
Yea, good video.
Old 01-06-2013, 04:11 PM
  #25
dakotawho's Avatar
22r or re?
Old 01-06-2013, 04:14 PM
  #26
Re, I believe.
Old 01-06-2013, 04:30 PM
  #27
dakotawho's Avatar
You checked all your fuses? I had a re blow the ign fuse under the hood, kept blowing it because the wire was grounded out....Any way you can get a pic of the motor.
Old 01-06-2013, 04:42 PM
  #28
Yea checked fuses all good, will get pic during week if I can.
Old 01-06-2013, 04:44 PM
  #29
It at one point sputtered for a few seconds on its own. But nothing more.
Old 01-06-2013, 04:46 PM
  #30
dakotawho's Avatar
hmmm....Check all the wiring inside, make sure it's all taped/covered like it should be....anything could be grounding it, i wish i was a little more help.
Old 01-12-2013, 04:29 AM
  #31
It's alive now, it was the afm, the wires in the rubber boot were bad. Thanks everyone for the help.
RaginAsian91
Engine Swaps
03-30-2019 09:17 AM
jasonty
41
12-23-2018 01:00 PM
wafoogalla
11-02-2016 11:02 AM
94yotaky
07-23-2015 07:50 AM
ZONAYODA
07-13-2015 07:17 PM
Quick Reply: 95 won't fire up.
