95' 4runner electrical problems, please help!
Old 06-10-2015, 09:16 PM
billabongsurfer's Avatar
Hello,
I have a 95 4runner with seemingly unique problems. Whenever I step on the brake, use turn signals, hazards, use power anything, it causes the whole system to short and the radio to pop, lights dim, ect. Also when i would turn the car off and leave it in ACC, I would loose all power for a few seconds, up to a few minutes. This also happened after the car had been parked a few times. Checked the fuses, all in good shape. Next checked the terminals, the negative broke as soon as I took it off so I replaced it with a new beefy one and the problem disappeared. All was well until a week ago when the problem came back. My mind instantly thought of the alternator, it makes perfect sense, however I don't want to spend the money on a new one if it isnt the problem.
I'm hoping you guys will have perhaps had this issue before and know what the solution is, thanks in advance!
Old 06-10-2015, 11:36 PM
wyoming9's Avatar
Red face
Simple to test the alternator on the vehicle with the engine running test the battery voltage.
Then put all the electrical load you would use in a normal drive.
At any time it should not drop below 12.5 VDC ideal would be in the 13VDC to 14VDC but age plays a factor at times.
Old 06-11-2015, 04:01 AM
Staff
Terrys87's Avatar
I take a wire brush to all my ground wires and to where they connect to. Sounds like you have some corrosion that can keep from getting a good connection as well.
Old 06-11-2015, 04:37 AM
kcaudill's Avatar
Do you have a trailer harness? Try removing all that stuff if you do. Toyota uses a floating ground to power the lighting, well everything matter fact. Ive seen those trailer harness screw things up.
MMA_Alex
25
04-18-2017 05:07 AM
coryc85
09-09-2015 06:24 AM
Jnkml
07-06-2015 01:20 PM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: 95' 4runner electrical problems, please help!
