94 toyota pickup has no reverse light
Old 03-06-2009, 05:10 PM
toy-o-tah's Avatar
just like tittle says. i just changed the bulbs and the fuses but it still wont go on? i think the guy that had this truck befor me put all 30amp fuse in every socket is that okay? and one of my friends tried to see if power where going thru when the reverse is on but no power showed up? can anybody help me...
Old 03-06-2009, 05:18 PM
rock slayer's Avatar
passenger side of the tranny there is a plug that goes to the reverse light switch in the tranny check the connection or the switch might be bad
Old 03-06-2009, 05:21 PM
toy-o-tah's Avatar
where is the switch located? is it easy to change?
Old 03-06-2009, 05:28 PM
NYChopshop's Avatar
first off, NO! a 30 amp fuse in everything may not set the wires on fire, but some of the things on the other end of the wires might go buh-bye. I say get out (or pick up on ebay like I had to) the 'ol owners manual get a variety pack of fuses, and replace them to spec. Probably not the source of your problem, however. I have the same problem. I assume you have a manual transmission. If thats the case, there is a reverse light switch mounted on the topish of the transmission. Its a cheap part, but a fiddly repair. My mechanic told me he'd do it for me for $50 and I'll take him up on that when I get my clutch master cylinder replaced this month. Also, I'd advise you to pick up the factory repair manuals (not just the Haynes one or whatever), ebay is also a good place to check for that.
Old 03-06-2009, 05:34 PM
Fossilized
Staff
dropzone's Avatar
X2 on getting your fuses back to stock specs. Who ever put 30 amp fuses in every circuit is suffering from some mental disease. The purpose of a fuse is to help protect electrical circuits. A 30 A fuse in a 10 amp circuit is asking for trouble, I am suprised nothing has melted or caught fire.
Also check your grounds in addition to checking back up switch.
there is link to online service manuals in my sig, you can find wiring diagrams there too.
Old 03-06-2009, 05:42 PM
toy-o-tah's Avatar
i cant find the oem specs for the fuse? can you send me the link and i have auto trans.. would the switch be at the same place?
Old 06-26-2016, 03:12 PM
bynutbuster's Avatar
A few years later, and I also came across this problem. My back up lights worked fine cuz I saw them reflect in a window,then one night whent to back up and pitch black. look in books for fuse location naa!.Useless , so checked. plug connection on reverse switch w/test lite.Nothing, rubbed end on frame harder ,made contact, light glowed orange. Argg! ,took out digital volt meter set to DC scratched frame somemore 5 volts ,scratched harder 12.4 volts. So 365000mi. I need to change the reverse switch on my 93 pick up.
Old 06-27-2016, 08:11 PM
RAD4Runner's Avatar
Before you replace the switch, try to see if it can be cleaned. 365000 miles worth of dirt may keep contacts from making good connection.
Also verify that you're getting full 12V on the other side of the back-up switch.
Aleeex_u
06-05-2016 06:52 PM
Gamble_STi
06-27-2015 07:54 PM
94hiluxZE
06-22-2015 10:42 AM
infinityisfive
06-16-2015 06:51 PM
runninclean
7
07-05-2002 06:25 PM
Quick Reply: 94 toyota pickup has no reverse light
