94 toyota pickup arking from the distribrutor to coil.
Old 01-29-2011, 07:27 PM
sis004runner's Avatar
i have a 94 toyota pickup 2wd a/t 22re. problem im haveing is that i hear a zap zap and i see arking from the distribrutor to coil. i just had put new wires, cap, rotor and plugs. anyone have this issue? this could be why my truck has no power and it bogs. doesnt look like its the coil plug wire looks like the wire from the distrib to coil. the electrical wire. thanks
Old 01-29-2011, 09:38 PM
myyota's Avatar
I would check the plug wires to make sure there good, even new plug wires can be bad. Also check the coil, sometimes the coil can get a crack in the plastic and it can arc through the crack to ground. The same thing can also happen to the distributor cap. When you replaced the cap, rotor plugs, and wires did you use oem replacements ?.
Old 01-30-2011, 05:22 AM
xxxtreme22r's Avatar
Originally Posted by razed
Considering the coil and distributor are like what, 2 feet apart, arcing from the dizzy to the coil is very unlikely.
Or are you talking about the hall-effect / pickup wires that run from the distributor to the igniter?
^^^this and
if it's arcing from the dizzy to coil, I want your coil that's a pretty strong coil ya got there. lol.
Or do you mean arching front the coil to coil plug wire that go to the dizzy, or the coil wire to dizzy. Or the wire harness to/from the igniter from the coil.
Old 01-30-2011, 11:04 AM
thanks im gonna check the coil see if there are cracks. i got everything at autozone. the plugs i got are ngks.
Old 01-30-2011, 11:08 AM
tried4x2signN's Avatar
Location: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
I bought a V6 with 170k that did this... It had the original plugs and wires on it.
There was so much resistance in the wires it was trying to find a path out and arced like crazy.
Changed the plugs and wires and it ran like a champ.
Old 01-30-2011, 11:31 AM
fierohink's Avatar
Maybe he's running a new Mr. Fusion coil pack generating 1.21 Gigawatts of electricty
6th Gear
19
12-10-2019 07:31 AM
Weidle
01-21-2019 05:39 AM
Aleeex_u
06-05-2016 06:52 PM
Peteyg39@hotmail.com
06-26-2015 08:15 AM
zytra
06-24-2015 08:14 AM
Quick Reply: 94 toyota pickup arking from the distribrutor to coil.
