94 4runner not getting spark
Old 01-26-2013, 02:43 PM
shakerGT's Avatar
I have a 94 4runner w/ 3.0 v6 4x4. Its not getting spark at all but will turn over sometimes. We've tried the battery, igniter, coil pack, distributor, plug wires, spark plugs, and tested all wires for power along with checking all fuses and relays and ecu. I'm out of ideas. Please help!
Old 01-26-2013, 03:03 PM
bone collector's Avatar
How do you know its not getting spark? any codes??
Old 01-26-2013, 03:07 PM
shakerGT's Avatar
Did the spark plug test. Pulled each plug and touched it to metal. No code reader. No cels
Old 01-26-2013, 03:43 PM
sometimes codes are stored in the ecm that dont trigger the cel. All you need to read codes on our trucks is a paperclip in the diagnosis ports. I believe its e1 and te1 to jump and then the cel will flash,
Old 01-26-2013, 04:05 PM
Co_94_PU's Avatar
Pull the distributor cap and make sure its turning, and/or the valve covers and make sure the cams are spinning.
Old 01-26-2013, 04:14 PM
^^ ya that and check the afm and throttle position sensors per the fsm
Old 01-26-2013, 04:18 PM
Co_94_PU's Avatar
It's in dummy mode when cranking, should get spark if the sensor is working sensor is in the distributor and (could be wrong) runs off the cam(s). (I didn't bother to look it up )
Old 01-27-2013, 09:58 AM
shakerGT's Avatar
OK getting spark now but it now backfires out the intake manifold. Still won't start
Old 01-27-2013, 09:59 AM
shakerGT's Avatar
Everything is spinning
Old 01-27-2013, 10:22 AM
Co_94_PU's Avatar
"Black magic" or did you do something specific to get the spark back?
Set the ignition timing and adjust the valves.
*edit* reading fail. can't do a proper timing setting if it doesn't start. You can adjust the valves and verify the cam timing for a place to start.
Old 01-27-2013, 11:30 AM
shakerGT's Avatar
How do I do that
Old 01-27-2013, 01:38 PM
Co_94_PU's Avatar
Guessing you mean the cam timing? Not as easily as a 22re..
Pages Eg2-34 and Eg2-35, actually the whole section but the timing marks are on those pages.
And the v6 doesn't have adjustable rockers. (newbie mistake on my part I don't have v6..) It uses shims (not sure if these come in different sizes, someone will be along to correct me I hope..). Basicly you can't have the problem where the adjustments are wrong and the valves aren't sealing.
Manual pages Eg2-74, covers reinstalling the valves and shims.
Which means if the cam timing is correct and the distributor is in the correct position, you should have spark at the right time atleast while the starter is turning.
There are a few reasons you could get intake fires with correct timing, the worst of which is a stuck/bent valve.
And you didn't answer my question.
If you can't point to a "this was obviously bad and replaced" You're wasting your time and money throwing parts at it. You've replaced the sensor(distributor) and the computer, but did you test either one or the wires inbetween the two?
Old 01-27-2013, 02:39 PM
Good point Co 94 PU..... what motor, tranny etc are we dealing with??
Old 01-30-2013, 05:26 AM
shakerGT's Avatar
Issue resolved! Distributor was out of time.
sandyota
02-04-2021 11:16 AM
Eggslinger
06-08-2019 03:32 PM
smiley52
07-11-2015 05:16 AM
88runnergomas
07-09-2015 01:12 PM
Huntingtruckcletus
07-08-2015 05:26 PM
Quick Reply: 94 4runner not getting spark
