93 4runner back drivers side coolant leak
Old 02-20-2012, 01:14 PM
butler239's Avatar
hey i have a leak i need some advice on, its coming from some metal part on the back of the motor on the drivers side. its the 3.0. i attached 2 pictures, any help would be great thanks.
Old 02-20-2012, 02:26 PM
ksti's Avatar
Pictures not real clear. Is it coolant or oil?
Old 02-20-2012, 02:45 PM
rworegon's Avatar
Check the u-shaped coolant hose at the back of the engine.
Old 02-20-2012, 05:47 PM
butler239's Avatar
i saw that u hose and it felt pretty dry, its just so damn compact back there its hard to tell. but it seems is coming from somewhere on the bottom of that u hose.
Old 02-20-2012, 07:56 PM
California's Avatar
Taking the hood off is easier than it seems, and makes the U-hose checking a lot easier. I've squatted on the plenum before.
The following users liked this post:
1993sr5 (06-01-2023)
Old 03-22-2012, 06:15 PM
butler239's Avatar
anyone ever hear of the block cracking on a 3.0? i cant find where its leaking anywhere. almost seems like i need to pull the motor to see the source
Old 09-02-2012, 11:23 AM
954Runner3VZE4X4's Avatar
Did you ever find the source of this leak? I have one from the exact same spot and I think it's the head.
Old 09-08-2012, 08:16 AM
butler239's Avatar
i never did find where it was, shes been sitting for 7 months now and now im finally gonna start taking the motor apart to see where its at.
Did you find out it was the heads leaking?
Old 09-08-2012, 08:31 AM
No I figured out it was the intake manifold gaskets leaking out. I don't want to replace them till I have something else I need to replace. Hope that helps.
Spicer
06-10-2020 08:39 PM
voiddweller
19
05-02-2016 09:10 PM
GorgeRunner
06-27-2015 07:01 AM
WI Girl
06-25-2015 03:45 AM
yamaha73
06-18-2015 06:19 PM
Quick Reply: 93 4runner back drivers side coolant leak
