92 22RE will not start
Old 11-26-2011, 06:24 PM
Antairus's Avatar
Just rebuilt a 22re.
I have fuel
I have spark
injectors are clicking.
I took 2 plugs out pistins are going up and down
stuck a qtip in there smell gas on it.
distributor is rotating.
Why will betsy not start?
pleas advise amazing ones
Old 11-26-2011, 07:52 PM
92dlxman's Avatar
can only guess that timing may be wayyyyyyy off.
have one guy crank it while the other guy rotates the distributor to adjust timing. move the distributor slow. if that doesnt do it, i would verify proper dist./cam gear alignment
Old 11-26-2011, 09:23 PM
Mdumaw's Avatar
did you adjust the valves???? i believe the intake are .008 in, and exhaust are .012 in.
Old 11-26-2011, 10:06 PM
4wd4fun's Avatar
2nd on timing being off, and prob 180 degrees.
turn the crank so the timing marks line up and check your distributor for the rotor pointing at the 1 cylinder terminal
Old 11-26-2011, 10:14 PM
Inferno451's Avatar
I know you said the injectors are clicking, but make sure the ground wire on the intake manifold is hooked up. When you have everything out it falls underneath things and it's easy to forget. That's why mine wouldn't start after i did the head gasket.
Old 11-27-2011, 02:20 PM
Antairus's Avatar
Double checked the timing on the cam it was ok.
grounds are ok.
Rotated crank 180 and re aligned cam. PITA.
Set the dist @ 12 oclock and pushed it in. It rotated back to # 1.
no Codes being thrown.
The shop put in new springs and guides adjusted the valves.
It just rotates. It seems to rotate fast.
I just dont get it.
Old 11-28-2011, 05:40 PM
Antairus's Avatar
Vales Valves Vlaves.
So the head was cleaned and shaved a tad I guess.
The valves never closed all the way.
Thats why it would just spin and spin.
No compession with the compression tester.
Must be the valves.
Adjusted the valves.
Now it goes rarw rarw pop.
Dead batt. LOL.
I think we got it. We are charging it now.
Man you can really tell the difference in cranking now.
I will post again once we get it started.
bigjstang
08-25-2021 12:41 AM
Yota.Jay
07-23-2015 08:08 PM
bryan34w
07-06-2015 05:53 PM
colinmil
07-06-2015 04:03 PM
karbin
07-05-2015 11:37 PM
Quick Reply: 92 22RE will not start
