91 Toyota 4 Runner with a 3VZ-E has a miss, rough idle, won't start in cold weather.
Old 12-07-2013, 11:45 AM
DB3
DB3's Avatar
91 Runner with 3VZ-E has a miss, rough idle, turned idle/screw up so it wouldn't die when coming to a stop, and now will not start in cold weather unless pull started. It is freshly rebuilt with new timing belt, plugs, wires, cap and rotors, and injectors. Timing is set at 10 degrees BTDC. It has spark. It also when running at highway speeds will surge only once. But will do it periodically throughout a trip only at highway speeds never in town.
Old 12-07-2013, 11:58 AM
Cyberman's Avatar
Verify cold start injector is working, check that wires are hooked up correctly.
Yont283
09-23-2022 08:06 PM
newzingo
06-24-2015 01:50 PM
slider417
06-22-2015 10:18 AM
BTOWN4RUNNER
06-16-2002 06:08 PM
Quick Reply: 91 Toyota 4 Runner with a 3VZ-E has a miss, rough idle, won't start in cold weather.
