'91 4-runner Clutch Master Cylinder replacement
Old 07-19-2008, 09:36 AM
spudrunner's Avatar
Hi, how hard are these to replace? Is it just the 2 bolts on the firewall and the line connection or is there something else under the dash that needs attention?
Thanks,
Gary
Old 07-19-2008, 09:42 AM
TOYOTA 1's Avatar
i think you have to go under the dash and disconnect the master cylinder push rod from the clutch pedal. and then the line and mounting nuts..
i think thats it, its been awhile lol.
Old 07-19-2008, 10:12 AM
idanity's Avatar
should be pretty easy,
but
check to make certain your fluid is on its own master cylinder, cuz if its on your brakes, you may want to bleed them all afterward
1st rear right wheel
2cnd rear left(drivers)
3rd front right
4th front left (drivers side)
then clutch.
hope that helps.
Old 07-19-2008, 10:19 AM
spudrunner's Avatar
Yes, I was just under the dash with a flashlight. Looks like 2 nuts 1 being a lockdown. I'll try to figure it out, and yes the clutch and brakes are a different system.
Thanks,
Gary
Old 07-19-2008, 12:10 PM
spudrunner's Avatar
OK bought a new master cylinder. Says I've got to bench bleed it, well I don't have a vice here at home, so I'll have wait 'till Monday when I go back to work, starting to suck. Anyway to get around this?
Thanks,
Gary
Old 07-19-2008, 12:24 PM
idanity's Avatar
c-clamp..comes to mind.
putting in a few hours on saturday (overtime/)
just walking into a really busy sears and use a vice on display.
i know its redneck, but hey...beats waiting
Old 07-19-2008, 12:46 PM
SLOWBOOST's Avatar
but
3rd front right
then clutch.
hope that helps.
what has the clutch and brake system all together? ive never seen or heard about that before.
you dont have to bench bleed it, it justs saves time when you try to bleed the clutch line. its two bolts, the line, and the pin on the clutch pedal under the dash.
smthwsn357
05-01-2024 07:28 AM
mskalmus
05-28-2017 07:51 AM
09-04-2015 09:27 AM
Kalihi,HI
07-09-2015 04:29 PM
wilbertd
07-06-2015 07:39 AM
Quick Reply: '91 4-runner Clutch Master Cylinder replacement
