90-95 4Runner Transmission compatibility question
Old 03-17-2006, 06:44 PM
miket223's Avatar
I feel like I should know this question, but since these things never go bad I have no idea. I'm working on a 92 4Runner 4WD V6 Automatic. The transmission is bad and I need a junkyard unit. I'm going to get it from torque converter all the way back to the t-case. What years are interchangeable? I'm thinking all 90-95s are interchangeable and probably the 88-89s as well. Could someone chime in here and set me straight?
Old 03-17-2006, 11:11 PM
regularguy412's Avatar
Look here for more info:
http://www.4x4wire.com/toyota/faq/parts/
Mike in AR
Old 03-18-2006, 04:59 PM
miket223's Avatar
Thanks for the info. I figured they were all the same model transmission. I'm just wondering if there are any suddle differences between years that make them not a direct swap. For example, silly stuff like wiring harness connectors, cooler lines, etc.
Old 07-14-2012, 02:59 PM
Swillis11's Avatar
Sorry to revive an old thread but...
I am also trying to replace the tranny in my 95 4runner and I have found a 91 at a wrecking yard. A few shops I have called say that I can't use the 91 tranny in my 95.
What subtle differences, if any, are there that would prevent me from putting the 91 A340H + Tcase in my 95 4runner that also had the A340H? That link above suggests that they are compatible but I am not willing to go through the work unless someone could explicitly confirm this.
Appreciate anything that you guys come up with.
Old 07-23-2012, 10:10 AM
Swillis11's Avatar
Can anyone confirm this info that has either done the swap or has worked on 95 4runner automatic trannys?
Old 07-09-2013, 07:42 AM
joevanvliet's Avatar
Did anyone ever solve this? I am wondering the exact same thing myself...
Old 07-09-2013, 09:01 AM
Swillis11's Avatar
Yeah, even though I asked this a while ago, this is still relevant to me. If anyone knows it would be appreciated.
mskalmus
05-28-2017 07:51 AM
TURBOrunnerNM
07-22-2015 11:01 AM
87turboPA
07-12-2015 07:49 AM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: 90-95 4Runner Transmission compatibility question
