90 4runner timing belt
Old 01-03-2013, 09:41 AM
Richoyta's Avatar
I'm changing out my timing belt on my 90 4runner and at TDC my cam sprockets are off a tooth from being aligned can someone tell me why? I have advanced the crank clockwise 360 degree's 3 times and they are still off a tooth? when I aligned them and not the crank, the crank was at 15 degree's instead of 0.
Old 01-03-2013, 11:24 AM
rworegon's Avatar
Off a tooth compared to what? If you are looking at the painted line on the new belt it will be off. What matters is that every 2 revolutions of the crank the crank and cam aligns to the proper TDC marks.
MudHippy recently described the way to put the belt on so it aligns correctly without the 'skipped' tooth issue. A search should pop up the thread.
Old 01-03-2013, 02:23 PM
Richoyta's Avatar
Off a tooth of the cam pulley's in reference to the painted marks above them.
Old 01-03-2013, 03:04 PM
rworegon's Avatar
Have you seen this thread?
1990 4runner 3vz-e motor cam timing....page 2 has what you may need
Old 01-05-2013, 08:37 AM
Richoyta's Avatar
Thanks rworegon!!!
voiddweller
19
05-02-2016 09:10 PM
vasinvictor
01-20-2016 12:39 PM
layifioren
10
07-06-2015 02:26 PM
crazypaint
06-23-2015 03:27 AM
infinityisfive
06-16-2015 06:51 PM
Quick Reply: 90 4runner timing belt
