89-95 IFS Trucks With 37" Tires... Completely Confused.
Old 03-24-2014, 09:32 AM
1990Toy4x4's Avatar
Originally Posted by highonpottery
It's totally possible to pull this off, but why not just stay with a more moderately sized tire under 35" and instead invest your money in traction devices/lockers and/or gears? 37" tire isn't going to help you at all when you're spinning single tires from open diffs. Plus, do you have enough lift to clear a 37 or are you going to use a cutoff wheel?
Thanks for the reply Highonpottery. You make some great points there , but I have decided on the 37s for piece of mind (in deep snow) and plus 37s just looks darn b@dazz to be honest. I have a 4-5 inch Rough Country suspension lift, and 3 inch body lift which is waiting for install before the tires go on. Thanks again for your reply.
Old 03-24-2014, 09:34 AM
1990Toy4x4's Avatar
Originally Posted by Roark
My friends up north run 33 9.5 or 32 9.5 with moderate success. A good snow tire plus 4Hi will do wonders. Add snow chains, bit of weight in the rear, and your truck won't even try to slide off the road. 37s are useless unless you're driving through crazy deep snow banks or something..
Thanks Roark for the tips. Yes I do plan on traveling through deep snow so 37s should be very useful in my situation. Thanks.
Roark's Avatar
Be sure to hit up some pics when you mount the 37s
Old 03-24-2014, 11:03 AM
wyoming9's Avatar
Red face
It all depends on the type of snow are you breaking a trail .
Or driving on hard snow pack that was like my driveway most of the winter
Then of course temperature plays a big part the colder the better the traction.
It all comes down to what your use is I run all 235/75 /15 tires on all my Toyota 4x4`s Because they work for me.
Being able to mix and match tires across 8 or 9 vehicles makes it nice.
Old 03-25-2014, 01:12 PM
  #25
JonnyBoy's Avatar
You planning on something like this, but with more lift?
https://www.yotatech.com/forums/f100...ow-run-277406/
Old 03-25-2014, 01:43 PM
  #26
Redeyejedi's Avatar
i think you should not just be worried about the tire size for the truck but that size while pushing all that snow.
i'd go with 33's pr 35's, chains, and lockers. if the snow is that craycray, just go with mattracks.
[youtube]GmI8oJEYJmc[/youtube]
are you trying to go much deeper than this?
Old 03-26-2014, 03:58 AM
  #27
1990Toy4x4's Avatar
Yes Sir, same size tires but more lift. I was deciding on 37" Toyo Open Country MT tires at first, but then I heard they are not particularly the best suited for snow and wet roads and ice so I discovered the TrXus tire which I read is a beast in the snow/ice/wet conditions.
Old 03-26-2014, 04:01 AM
  #28
1990Toy4x4's Avatar
[YOUTUBE]GmI8oJEYJmc[/YOUTUBE]
I have viewed videos of trucks with those tracks attached before. That is really interesting to watch, so thanks for that video. I do plan for snow even deeper than that. Thanks.
Old 03-26-2014, 05:21 AM
  #29
strykersd's Avatar
If I were to run 37s on my truck I'd run a total chaos idler arm and a heim-steering upgrade. Changing parts in the snow sucks!
Old 03-26-2014, 06:11 AM
  #30
xfactor203's Avatar
Just out of curiosity, where do you live that you need 37" tires to deal with snow? Are you off the road system somewhere?
Old 03-26-2014, 06:37 AM
  #31
1990Toy4x4's Avatar
At current time I live down in the South (in Texas) where there surely isnt much worry for snow, but I am soon moving back up to the North and will be located deep out into the country in an area that gets much snow and where I may have to make some of my own roads.
So as a result it will be 37's I decide on especially now since based on the replies here, it seems absolutely do-able like I was hoping to read. Thanks.
Old 03-26-2014, 06:49 AM
  #32
1990Toy4x4's Avatar
Thanks for that advise. After the tires (and lift) go on, I am going to consider replacing front end parts with heavier duty pieces. I am thinking idler arm, steering upgrades, and CV joints/axles replacements. Since I wont be rough on it, I guess I can get by for awhile on stock parts. Thanks.
AustinTaco
08-22-2022 10:45 AM
Ott47
06-26-2015 05:21 PM
zytra
06-24-2015 08:14 AM
Chooch
06-19-2015 03:05 PM
Quick Reply: 89-95 IFS Trucks With 37" Tires... Completely Confused.
