89 22re Tensioner Pulley help plz
Old 02-29-2012, 02:57 PM
22RE1989's Avatar
I need some info on my tensioner pulley. im pretty sure its called the tensioner pulley, it doesnt hold the drive belt or the ac belt. I need to know how to remove the pulley from the bracket it is on, and if i buy a new one, does it come with a bracket or just the pulley? im worried that its pressed on the bracket, just figured id ask before i go workin on it. its makin a lil noise and i wanna replace it. thnx
Old 02-29-2012, 03:50 PM
slacker's Avatar
Powersteering idler pully perhaps ? there is a nut on the face of the pully 17mm I believe , you need to loosen that . Then there is a adjuster bolt on the bracket ..... back that out , and you should be good to go . once you have it off , if you have a look on the back side of the pully , you'll see there is a snap ring . If you remove that and "punch" out the bearing , you can just replace that for about 5 bucks ..
Old 03-20-2012, 04:14 PM
22RE1989's Avatar
Thanks man. i feel like a dummy, but i like to know things before i tear into a motor.
Dennisx2
08-10-2015 06:48 AM
Dennisx2
08-04-2015 01:26 PM
Esibnitsud
07-21-2015 08:51 AM
PlayAwhile
07-20-2015 11:36 AM
Quick Reply: 89 22re Tensioner Pulley help plz
