89 1st gen 4Runner- electrical problem
Old 12-28-2013, 11:50 AM
air_wolf's Avatar
hello,
I have a 4runner 1st gen w/3vze engine, Canada version. I don't have a service manual for it (and couldn't find one - I had found for 88 but 22 and 1993 but 2nd gen).
the problem is that I don't have instrument lights, no daytime lights and no voltage on their wires (front and rear). turn, headlights, hazards and dome lights are working. so there is ground. fuses are ok.
where could be the problem?
thanks
Old 12-28-2013, 01:45 PM
sebastianholmes's Avatar
did you check the fuses inside the driver side kick panel? the "engine" fuse i know controls the instrument lights and possibly the daytime lights.
Old 12-28-2013, 10:19 PM
air_wolf's Avatar
checked
I think I'll start a wire-by-wire checking. everything looks good on it... but it's not working
PS now I see that I'd posted in the wrong section
Old 12-28-2013, 11:22 PM
Fossilized
Staff
dropzone's Avatar
moved to the correct folder for you.
I had a similar issue on my '81. My fuses etc look fine but it turned out to the be contacts in the fuse box that were not allowing the fuse to complete the circuit. i cleaned the contacts and crimped them together slightly. issue resolved.
Old 12-28-2013, 11:53 PM
air_wolf's Avatar
I'm doing the same thing. put some contact cleaner an we will see. It's the last, but not the least. The least is to check for a relay under the dash, somewhere in the middle.
thanks for moving it.
Old 12-29-2013, 12:32 AM
RAD4Runner's Avatar
Originally Posted by air_wolf
checked
Yes, Don't just look.
Verify with other owners that you're looking at the right fuse.
Check for voltage at power side of fuse, then load side, then check every wire to the lights concerned until you see where you lose 12V.
Old 12-29-2013, 01:04 AM
Gamefreakgc's Avatar
You might find this helpful:
http://personal.utulsa.edu/~nathan-b.../4lighting.pdf
There are some parts I'm not familiar with, like the daytime running light and such. If one of those relays went bad, it might short circuit the rest like you are experiencing.
Old 01-04-2014, 05:54 AM
air_wolf's Avatar
I started to break it apart!
tomorrow I will make a new front wiring.
Attached Thumbnails 89 1st gen 4Runner- electrical problem-20140104_140402-medium-.jpg   89 1st gen 4Runner- electrical problem-20140104_140415-medium-.jpg
Old 01-04-2014, 09:12 AM
RAD4Runner's Avatar
??? You don't even know where the problem is, and now you're making your own wiring?
Old 01-04-2014, 04:27 PM
wyoming9's Avatar
Red face
Sounds like the DRL relay!
Did 89 have the integration relay that it seems 9x10 to the 6th circuits run through??
Old 01-04-2014, 09:12 PM
air_wolf's Avatar
not all the front, only daylights. to see if it is a switch problem. (could be...)
@wyoming9: I had searched but did not find any info on that. and no DRL relay. under the stereo, in the middle of the dash, I have the 3rd fuses/relay block with the heater.
Old 01-04-2014, 10:02 PM
RAD4Runner's Avatar
not all the front, only daylights....to see if it is a switch problem. (could be...)
Oh I see... Sorry , BUT no need to take change wiring. Just test switches first, listen to relays click...
IF switched power:
Just check for voltage before the switch. If there's voltage before switch, turn switch on. There should be voltage
If switched-ground like tail light switch:
Check for continuity to ground on ground side of switch. Then, turn switch on. Measure continuity to ground on side of switch away from ground. There should be continuity is witch is good.
If you don't know where to test, and If you have schematic, pls post it here so we can indicate on schematic where to do tests (Like I do here on a 22RE schematic)...
Old 01-05-2014, 12:43 AM
wyoming9's Avatar
Red face
If it has DRL`s it needs to have a relay.
That is what makes them work. Does it even have them??
I really wish I had the 89 EWD to know for sure.
Old 01-05-2014, 06:30 AM
air_wolf's Avatar
well... it seems like tail relay is not working. measured it is ok with and without voltage. but on the car... weird.
put it back all together and repaired some wires and cig and stereo.
thanks for support
06-01-2021 01:51 PM
sandyota
02-04-2021 11:16 AM
the1998sr5
15
07-14-2020 08:35 PM
Yota.Jay
07-23-2015 08:08 PM
coryc85
07-06-2015 04:07 AM
Quick Reply: 89 1st gen 4Runner- electrical problem
