88 4 runner transmission noise, possible causes?
Old 11-20-2011, 09:13 PM
Philbert's Avatar
subscribed.
i am about to replace mine and will have a "leftover" t case as well.
good luck!
Old 11-20-2011, 09:17 PM
4wd4fun's Avatar
Originally Posted by Philbert
subscribed.
good luck!
We'll see what happens.
Old 11-21-2011, 07:59 PM
4wd4fun's Avatar
Thanks for the help guys.
Old 11-28-2011, 07:24 PM
4wd4fun's Avatar
subscribed.
good luck!
Starting a new thread... coming soon... maybe.
Old 11-28-2011, 10:25 PM
  #25
Philbert's Avatar
Keep us posted! I have a W56 in the garage, new rear main seal, and my Aisan cliutch kit just arrived today. But I need to clear out my garage first
Old 11-28-2011, 10:38 PM
  #26
4wd4fun's Avatar
I will try.
Old 12-09-2011, 11:58 PM
  #27
4wd4fun's Avatar
ok.
I've found that a top shift transfer case from a w56a/b will bolt to a forward shift transmission (w56c/d) and work fine- but will need some fairly simple mods to the plate to blockoff the transfer case lever position on the transmission: for some reason, my post about that was moved to the newbie section- dont know
I've purcased a b with top shift tcase and will be installing that soon, probly sunday, avoiding issues with a/b & c/d use.
dual case setup is probly a few months off from doing if it even happens.
Old 12-21-2011, 07:21 PM
  #28
4wd4fun's Avatar
trans work is starting tomorrow, 12/22.
i'm not doing a dual case setup so the top shift case attached to the trans (w56b) being replaced will be available for someone else to use. We're going to be doing the work just north of Tukwila, WA, so if you want it and are in the area claim it. I have a friend going to Cali over the weekend so if you live not far off the 5 between seattle and stockton and want it say so soon.
Otherwise, the local wrecker will end up with it and i'd hate for that to happen.
Old 12-22-2011, 09:48 AM
  #29
skypilot's Avatar
Believe it or not AAMCO sometimes buys these for parts. I got a few bucks for my spare trans that rather than nothing at from a wrecker.
Old 12-22-2011, 09:06 PM
  #30
4wd4fun's Avatar
thanks for the advice. hadn't thought about aamco at all and it would makes sense
but, the trans work didn't happen so who knows what happens next
06-01-2021 01:51 PM
toyota32
07-06-2015 05:42 PM
Jnkml
07-06-2015 01:20 PM
Vargntucson
07-04-2015 12:15 PM
CJ94yota
07-03-2015 10:14 PM
Quick Reply: 88 4 runner transmission noise, possible causes?
