88 22re wont start
Old 02-27-2010, 11:09 AM
yoda user's Avatar
Unhappy 88 22re wont start
Just changed the timming cover on my 22 water was getting in the oil when I took it apart I saw that the timeing chain had been replaced so left it as it was now that I put everything back together the truck won't start and when I start it it it makes a pop noice and smoke comes out the throttle body but when I start it directy with the key in off position and spray starting fluid in the throttle body it starts normal untill the fluid runs out...so what's wrong really stumped and don't know what to do...
Old 02-27-2010, 12:52 PM
CyMoN's Avatar
sounds like your timing is off
Old 02-27-2010, 01:42 PM
yoda user's Avatar
That's what I was thinking. Truck ran fine befor could it be that my distributor it a tooth off?
Old 02-27-2010, 01:46 PM
BigBluePile's Avatar
it's possible, what position was the rotor in when you put the dizzy in?
Old 02-27-2010, 01:54 PM
yoda user's Avatar
It was at about 1 o clock it was pointing at the number 1 spark plug
Old 02-27-2010, 01:58 PM
IIRC, with the #1 at TDC I believe, the dizzy should be positioned at like 10 or 11 o'clock because it's going to turn a bit as it engages splines to the 12 o'clock position. Check your FSM to make sure...
Old 02-27-2010, 01:59 PM
yoda user's Avatar
I marked it and its right bak were it was when I took it off just tried starting it after I loosed and rotated it just a little and it really pop this time it sounded like a gun shot not sure if I should keep trying to start it can I cause any damage by doing this?
Old 02-27-2010, 02:01 PM
What's the manual say to do?
Old 02-27-2010, 02:34 PM
yoda user's Avatar
Just put it at tdc and the daizzy was at about 7 or 8 o'clock pulled it out and rotaded it to about 11 and it doesn't back fire any more and sound likes its going to start stated to try the starting fluid again and my battery is dying its sound a lot better though thanks for the advice...
Old 02-27-2010, 02:35 PM
hope you get it started!
bigjstang
08-25-2021 12:41 AM
Yota.Jay
07-23-2015 08:08 PM
bryan34w
07-06-2015 05:53 PM
colinmil
07-06-2015 04:03 PM
karbin
07-05-2015 11:37 PM
Quick Reply: 88 22re wont start
