88 22RE starts but wont stay running
Old 06-14-2011, 08:13 AM
EdYota's Avatar
Folks,
88 4x4 22RE Truck starts but wont take gas to continue running. Changed fuel pump..same problem, changed fuel filter...same problem, changed mass air flow...same problem, changed ignition switch and harness...same problem. Dont know what else to change out!!Truck will start on initial fuel but will not run on its own after the initial gas is gone. Like the injectors might not be getting a signal to kick in or something. Will idle real rough if air intake is blocked but wont take gas. Any help, comments or ideas would be greatly appreciated.
Thanks,
Ed
Old 06-15-2011, 07:48 AM
bicklebok's Avatar
I have never had to work on my fuel system on my truck, so I may not be too much help. Do you know that the fuel pump is getting power and is pumping?
Old 06-15-2011, 07:51 AM
sebastianholmes's Avatar
get your injectors cleaned? check that they are firing correctly? sounds like you run for a second on the cold strt injecor then your normal injectors arent giving enough fuel for it to run.
Old 06-15-2011, 09:20 AM
TNRabbit's Avatar
Sounds a lot like an issue with the VAFM. MAKE SURE you don't have any shorts in the harness leading up to the VAFM (there is no MAF on these trucks).
Old 06-15-2011, 03:58 PM
angrybob's Avatar
How do you *know* its not getting fuel?
Curious if you know or thats what you think? Once warmed up, is it OK?
Old 06-15-2011, 05:04 PM
EdYota's Avatar
Fuel pump pumping, or at least when the key is in the start position, Like Sebastion said, I believe its running on the CSI and for some reason the injectors arent kicking in???Put a new VAFM on itand that didnt help either. At least I have new parts on the truck and good spares too. Ha!
I can make it run longer by just turning the key to start position and holding it there without pushing in the clutch to keep the pump running so more fuel gets pumped up but once I push the clutch in and it starts that initial fuel gets burnt it will not take anymore gas and dies out. will check the injectors and wiring once again. Thanks for the help and if any more ideas come to light please let me know.
Ed
Old 06-15-2011, 05:17 PM
you should have someone turn it over and put a screwdriver or something on the injectors to listen for the little tick they make when they fire. if theyre firing they may be clogged and need to be cleaned. it may be in the wiring somewhere too.
Old 06-15-2011, 05:23 PM
takeitoutgetitdirty's Avatar
Get a noid light and check if the injectors have power. Could be a problem in the harness, Splices coming apart or corroding. Check the ground going to the intake manifold. Could also be the solenoid resistor.
Old 06-15-2011, 05:34 PM
Dras16's Avatar
Could be a few different things. I would first check your air intake tube to make sure its not cracked, that would make it do that. Also your computer under your dash could be somewhere else to look also
Old 06-15-2011, 05:44 PM
corax's Avatar
Kids . . . 4crawler has a lot of this already spelled out. The VAFM or COR (circuit opening relay) is what turns on the fuel pump after the engine starts initially
The E1-FC connection is what triggers the fuel pump to operate via the Circuit Opening Relay
start with these 2:
http://www.4crawler.com/4x4/CheapTricks/AFM/index.shtml
http://www.4crawler.com/4x4/CheapTri...shtml#FuelPump
Old 01-07-2014, 06:29 AM
GasTurbine's Avatar
Hey ed, did you ever get it figured out. I've been having a very similar problem? (Yes. I see last activity was 2011, hoping an email notification may awaken the answer). Not trying to resurrect. Sorry guys, Ive just at wits end.
Old 01-08-2014, 02:58 PM
EdYota's Avatar
re: 88 22RE starts but wont stay running
GasTurbine,
I did finally get the ol Yota running fine. It turned out that the fuel rail and injectors were partially plugged with gunk. Took the rail off and injectors and cleaned them really good with solvent and air, replaced the o rings ,drained the tank and put in fresh gas and some stabilizer (heet) and it fired up 1st turn of the key! I guess where it sat for a long time the gas broke down and turned to a sludge of some sort and me bein hard and headed and all, kept trying to get it to run, pumped that sludge into the injectors. Been running ever since! Hope this helps you out cos it bout drove me nuts!!
EdYota
Old 06-05-2015, 09:19 AM
ray_ray85's Avatar
hello ive read some of these posts and my 88 yota is doing the same thing will start but wont stay running put a new key switch in and still the same thing havent got the chance to check fuel pump or filter figured if it starts then its getting sme gas
puffin04
07-10-2015 09:17 PM
bigblue82
10
07-06-2015 08:27 AM
sonic concepts
07-01-2015 02:33 PM
puddlepirate
06-30-2015 05:08 PM
serenity03k64
06-27-2015 07:59 AM
Quick Reply: 88 22RE starts but wont stay running
