87 4runner sliding window replacement
Old 08-28-2009, 08:10 PM
tnotheis's Avatar
87 4runner passenger side forward sliding window was broken into, I found a replacement window but cannot figure out how to get it replaced. The salvage yard used a pair of channel locks to bend the lip around the window up so I didn't get any hints from them. Someone must have been here before, thanks for the help ............
Old 08-29-2009, 06:04 AM
4banginRunner's Avatar
because the whole unit is held in with glue and comes out as one...
Old 08-29-2009, 04:27 PM
tnotheis's Avatar
Smile
Thanks, that info helps a lot, will tackle it Monday,
suppose to be a day without rain. It should not be
to bad once I get the whole window assembly out.
Looks like once the interior trim is off around the
window I can run a putty knife around to cut the
glue and remove the whole window.....
thanks again ........
Old 08-29-2009, 04:30 PM
myyota's Avatar
You should have bought the whole window, it would have been alot easier to replace.
Old 08-29-2009, 05:21 PM
4runnerx3's Avatar
You have to cut the glue and pull the window out and take the frame apart.
Old 08-29-2009, 06:11 PM
tnotheis's Avatar
Your awesome, thank you very much, I hope I can help someone in the future ......
clos88runner's Avatar
Heat Gun
I've been here...a heat gun (a regular hair dryer will not work) helps immensely. The glue will soften right up for you. The first window took me 2 hrs but I learned. Disassemble as above but before you cut w/ the knife use your heat gun and run the frame perimeter for about 15 minutes. Putty knife slips right in and before you know it the window pushes out nicely. I was able to clean the old glue right up with the help of some goo gone for a nice clean install after. Good luck!!!
Old 08-29-2009, 06:25 PM
tnotheis's Avatar
My Buddy has a heat gun I can use, I'll make sure I get it tomorrow so I will have it for Monday, have a good weekend, thanks a lot for the information ..............
Old 09-02-2009, 04:16 PM
tnotheis's Avatar
Window replacement went great, thank you to everyone for your help ....
Old 08-27-2010, 09:34 AM
Peyton's Avatar
Thanks so much for the instructions. Which manual did you take them from? I'm looking for a comprehensive manual for my '89 4Runner.
Old 05-29-2015, 02:16 PM
codfish28's Avatar
Smile The instructions
Those illustrations are from the original service manual from Toyota.
Very comprehensive but quite technical far as I know it is only missing one piece
of info and that is on changing the rear axle bearings.
arlindsay1992
01-23-2024 01:34 PM
AustinTaco
08-22-2022 10:45 AM
voiddweller
19
05-02-2016 09:10 PM
Outsane
06-24-2015 05:52 PM
infinityisfive
06-16-2015 06:51 PM
Quick Reply: 87 4runner sliding window replacement
