86 pickup bench seat swap question
Old 09-05-2011, 05:49 PM
Jordanlawrence's Avatar
Hello I have an 86 pickup with bucket seats and I want to put a bench seat it
I've found a ton of bench seats that are compatible but the problem im having is i have a center console plastic thing and a plastic casing around my stick shifter and 4WD shifter.
Where could I find a new stick shifter that would be compatible with a bench seat. The 4WD toyotas that came with bench seats from 86-88 did they have a small casing around the stick shift instead of the big plastic one I have now?
Old 09-05-2011, 06:06 PM
xxxtreme22r's Avatar
my 87 doesn't have a console, just the rubber boot and steel ring.
P.S. I hate my bench seat. Not all that comfy, especially that stupid bar they put behind it for "support". I have been on the lookout for some time to find a split bench and see if they are any more comfortable then the standard bench.
Old 09-05-2011, 06:10 PM
Where can I find a "boot and steel ring"? Or could I even change that out on my truck?
Yeah I don't really want to buy the bench seat but a guys selling a 60/40 split one and I have a wife and baby so I need it!
Old 09-05-2011, 06:20 PM
would this work ?
http://cgi.ebay.com/ebaymotors/TOYOT...item35a5e62e13
Old 09-06-2011, 05:53 AM
IIRC if you take your center console out you are left with your boot and ring which I believe might actually all one piece. That ebay link is just the boot.
Old 09-06-2011, 06:56 AM
Crimson Yota's Avatar
I'm curious on this too, my 82 came with no type of console, I can see the road/tranny when I'm driving, so bump for an answer!
I've also considered felt and fiberglass resin to make one.
Old 09-06-2011, 08:48 AM
dsal_86Yota's Avatar
I have a 86 pickup that has the bench but its a Auto. So try one of the covers out of a Auto trans one. Might be able to to a little cutting and use a little fiberglass and it could work. Also make sure you use a Yota bench. They have the little indent in the middle of the seat. that goes around the shifter area if you have to push seat forward.
Old 09-06-2011, 09:00 AM
Plenty of part out threads on here, just sayin, also I believe the dealerships/oem online parts suppliers still sell these. Not sure on the 83 though.
Old 09-06-2011, 10:16 AM
Okay thanks!
arlindsay1992
01-23-2024 01:34 PM
GreenLion
06-07-2021 10:49 AM
infinityisfive
06-16-2015 06:51 PM
Lowviz
07-22-2002 10:52 PM
Quick Reply: 86 pickup bench seat swap question
