Old 02-09-2016, 09:40 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Exterior Guides
Print Wikipost
86 Door Panel Swap Write Up
Old 04-12-2010, 11:51 AM
kiyobrown's Avatar
They did an ok job. Not sure if they were trying to or not, but 2 of the 4 screws for each speaker are into the metal frame behind the panel, so it's not completely free floating in there. And the sound deadening I used in there made them sound way better.
Old 03-10-2014, 05:50 PM
BigBluePile's Avatar
ZOMG sweetest mod eva!
Old 03-10-2014, 07:49 PM
Also, no need to cut up the wiring, simply repin the connector.
Old 03-19-2014, 06:08 PM
So the passenger side is a completely different story. You will have to modify the harness to fit it to the different switch.
It's easy enough though
Old 05-07-2015, 09:44 AM
  #25
phenomajon's Avatar
wiring diagram?
Originally Posted by PismoJoe
Thanks guys! Sorry for the late response, I accidentally unsubscribed lol
Kiyo- I think there's a lot of things you could do with that switch! Let me know what you end up doing when you swap your panels! (if you do, I checked out your 4runner album and yours look pretty nice as is)
Joe I was wondering if you could tell me the wiring color codes to do this swap I had the door panels in the plugs but you didn't describe which wires to connect to what when you did your swap if you could put that in your description or send me an email personally that would be so awesome I really want to do my swap I'm all ready to go but have no clue what wires connect to what thanks again for the help
Old 10-24-2018, 03:02 PM
  #26
noechavira's Avatar
Originally Posted by kiyobrown
Awesome write up! Thanks for the link. When I saw it at the junk yard the first time, just took a quick peek and said screw it, mine are in good shape. But I like those panels better, I will have to put this on the list of to-dos. Nice work dude!
I wonder if I could use that power mirror switch in the door, then find the blank cubby for the dash and get rid of that switch. Interesting......
Hey friend, I recently bought a toyota like yours and it does not have the relay door control, so obviously the windows do not work, could you tell me the number the relay has written? in the picture you took, it is not appreciated. I ask you to search for it by its part number
jasonty
41
12-23-2018 01:00 PM
rushw
07-18-2015 01:46 PM
94whiterunner
07-12-2015 07:15 PM
crashburnoveride
07-10-2015 06:39 AM
ItsJustD
07-07-2015 07:49 AM
Quick Reply: 86 Door Panel Swap Write Up
