86-95 IFS 4x4 GEAR INFO - READ FIRST HERE NEWBS BEFORE POSTING
Old 02-12-2010, 10:32 AM
kiyobrown's Avatar
Seems like this subject comes up here a lot. Here are some links to ..
1. Identify your gears, and what will swap into it.
2. Use the Gear calculator to input new tire sizes and possible gear ratios, and compare them to stock.
3. Links to threads on how to swap them, and some locker info as well.
1.
To find out gear ratios and codes.........
http://www.off-road.com/trucks4x4/ar....jsp?id=274535
https://www.yotatech.com/51260014-post25.html
pics on where to look on your vehicle to find out what gears you have....
http://www.brian894x4.com/Gearratiosanddiffs.html
To see what differentials are a straight swap......
http://home.4x4wire.com/erik/diffs/
2.
A tire size calculator for those that can't read tire sizes....
http://www.1010tires.com/tiresizecalculator.asp
A link to help you figure out what transmission you have, in order to input the info in the gear calculator... (Thanks MudHippy)
http://en.wikipedia.org/wiki/Categor..._transmissions
http://www.4x4wire.com/toyota/faq/parts/
http://www.4crawler.com/4x4/ToyVIN.shtml
or enter your VIN here.. http://www.toyodiy.com/parts/q.html
The gear calculator to compare stock vs. new gears and bigger tires....
http://www.grimmjeeper.com/gears.html
3.
And how to swap out the front IFS diff, with pics!!
http://www.gearinstalls.com/ifs.htm
Matt16's writeup of a rear third removal, just ignore the locker install (unless you are installing a locker, of course ) For second Gen 4Runner
https://www.yotatech.com/forums/f116...nstall-161405/
Since I added a thread of 4cyl diff locker installs, here is Justinlhc's V6 diff locker install, lots of pics!!
https://www.yotatech.com/forums/f116...p-pics-179241/
And Philbert's rear third removal, on an 87 4Runner. Different pics of parking cable, for those visual learners. (Thanks to Philbert!)
https://www.yotatech.com/forums/f116...e-pics-205316/
And since I addressed lunchbox lockers above,
If you want to fit an e-locker in the stock 86-95 housing....
http://home.off-road.com/~kemanuel/elocker/elocker.html
http://www.sonoransteel.com/phong/re...r.html#housing
http://www.4x4wire.com/toyota/tech/electric_locker/
This link has everything you need to swap the TRD in. Studs, gaskets and wiring harness.
http://www.inchwormgear.com/store/index.php?cPath=25_62
Cool switch panel options
http://12voltguy.com/web/index.php?o...hk=1&Itemid=43 (Thanks tried4x2signN)
Bonus Material!
And dealing with ADD (auto disconnecting differential) in a vehicle without the system.
http://www.4x4wire.com/toyota/tech/add/
https://www.yotatech.com/forums/f2/d...system-190329/
Or you run a vacuum line to the passenger side inlet, and cap the drivers side inlet. Easy as...... a cap and a vacuum line.
And I can't believe I forgot to add this one. A cool site with tons of pics. I have lost myself for hours in here...
Hope this helps. And please, if there are other threads/links that will help out, please post it up.
Old 02-12-2010, 11:05 AM
mt_goat's Avatar
Nice links. I never can find anything on that off-road site anymore. They had the best torsion bar adjustment writeup over there, but I can't find it anymore.
Old 02-12-2010, 11:21 AM
CappyKD's Avatar
Nice collection of links.
Old 02-12-2010, 11:27 AM
BigBluePile's Avatar
Good job Jason, how 'bout a sticky!
Old 02-12-2010, 11:46 AM
Tragic Drive's Avatar
Some advise here.. What I've been doing is saving the web page as a PDF file then storing it locally on my machine.
If you use firefox there is an add in that does it for you. All you have to do is click a button and wait a minute for the conversion to take place. Here is a link to the add-on
https://addons.mozilla.org/en-US/fir...?q=pdf&cat=all
Old 02-12-2010, 12:08 PM
waskillywabbit's Avatar
What would help if you veterans would start sending newbs to this thread or report redundant posts on other topics that you see. No way to find them all every day.
Old 02-12-2010, 12:16 PM
Magnusian's Avatar
Location: Downtown Heckronto, Ontario, Soviet Canuckistan
If only I could find this kind of wealth of information for 2wd 'yotas, the only 2wd forum I know of is crap for getting any real info, 'tis why I be here instead. At least some of this is relevant to me so, thanks!
Old 02-12-2010, 12:17 PM
92 TOY's Avatar
nice work KIYO.
everytime I come across a thread I like I subscribe to it. currently have just under 400, but that prevents me from wandering aimlessly....
quick question. I have a 22re and I'm running 31's...............
Old 02-12-2010, 12:19 PM
Originally Posted by 92 TOY
nice work KIYO.
Don't make me hurt you.
Old 02-12-2010, 12:24 PM
92 TOY's Avatar
But seriously, and I see what you mods go through. someone was asking this morning about 3vze head work and I thought i would tell him to search and then felt generous and posted up a bunch of links and the the thread was gone. (that right there is a run-on sentence).
so i ran the spectrum of emotions.
But i like what KIYO did as well as the other sticky's have great value too.
but honestly, a year ago, i did not know HOW to navigate this site and had neer been part of a forum before.......but now.....I get all sweaty when i don't check it every 10 minutes
Old 02-12-2010, 12:42 PM
I understand. It's a "Don't Feed the Bears" kind of thing. If you never make them search from the get go, they won't ever search, that is the problem now. Too many free loaders who feel "entitled" to information inside of doing a bit of work for it.
I have no problem sharing information and answer dozens of emails a day and posts on a variety of forums, but when someone asks something they could find with 30 seconds of effort it just pisses me off.
Old 02-12-2010, 01:29 PM
MudHippy's Avatar
This is one of the only links I know of to get the transmission gear ratio #'s for all Toyotas.
Seems to me as though it ought to be included in this thread, somewhere...
How 'bout a "sticky" about how to find the "stickies"...jk.
Old 02-12-2010, 01:33 PM
92 TOY's Avatar
not going to argue your point....and i know the search feature is more accurate than when i joined, or at least that's what i think. i did tell the poster this morning when he posetd a 2nd time to search and post if he needs to there.
Old 02-12-2010, 01:35 PM
CappyKD's Avatar
Old 02-12-2010, 01:37 PM
92 TOY's Avatar
Originally Posted by CappyKD
to the TOP of my list
Old 02-12-2010, 01:40 PM
kiyobrown's Avatar
Come on Cappy, isn't having an engine rebuild that started in August bad enough? Don't add insult to injury!!
And really, how many more times do you guys want to answer this question...
I have an 87, I put 31's on it now it feels slow as crap. I am wondering if I need to swap gears. How do I do it which ones do I need? what if I want to drop it and turn it into a lowrider, do I still need new gears? I found a set of gears from a Nissan will they work? How do I find out what kind I have? Does anyone know a good place to find gears? I want gears? Anyone have gears they want to sell me?
Old 02-12-2010, 02:02 PM
CappyKD's Avatar
I was trying to get to the top of his list...
https://www.yotatech.com/forums/f5/w...thread-203670/
Old 02-15-2010, 07:07 PM
rattlewagon's Avatar
good thread. found exactly what i was looking for.
Old 04-09-2010, 10:24 AM
tried4x2signN's Avatar
Location: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
Here's some more TRD stuff that's VERY important.
Since Downey is gone, so is his cable locker.
This is where Inchworm and 12Voltguy come in.
12Volt gut has the switches, and some other cool stuff: http://12voltguy.com/web/index.php?o...hk=1&Itemid=43
There is also a cool post in IH8Mud about a guy using the FACTORY antenna switch as a E locker actuator
...But I can't get it right now..
Old 04-09-2010, 11:28 AM
kiyobrown's Avatar
updated, Thanks.
Quick Reply: 86-95 IFS 4x4 GEAR INFO - READ FIRST HERE NEWBS BEFORE POSTING
