86 22re alternator question
Old 03-08-2010, 02:01 PM
sas'd22re's Avatar
I'm doing a 7mge swap and swapped the battery to the drivers side. My computer crashed and I lost all of my tear down pics. I want to make sure where the white 8 gauge wire goes. I believe its from the fuse box then to a bracket with a terminal (near the check plug), then to the alternator. Could you post a pic of the drivers side wheel well, or just confirm this for me? Thanks for the help! I'm running 4 gauge welding cable now and want to get it right the first time
Old 03-08-2010, 05:57 PM
sas'd22re's Avatar
Bump. Anyone have a shot of under the hood? Or of the drivers side wheel well? Or want to have a quick look under the hood to make sure that the white wire that goes from the fuse boz to that bracket then to the alternator. Thanks!!!!
Old 03-08-2010, 06:17 PM
iamsuperbleeder's Avatar
you'll have to excuse the mess of other wires half-ass alarm system install, lol
hope this helps
Old 03-08-2010, 06:50 PM
sas'd22re's Avatar
Lol, no problem about the mess. I'm trying to get my wiring as clean as possible and I had to cut probably 20-30 feet min of alarm wiring that was just shoved behind the kick panel. I'm wondering where that wire goes from the 'L bracket' thing with a single threaded terminal on it. On mine there was just 1 single white 8 gauge wire that goes to that L bracket then I THINK it goes to the terminal on the atlernator. I just want to be 100% on this before I start soldering, taping and looming everything. Thanks bleeder! How's the rig?
Old 03-09-2010, 11:15 AM
sas'd22re's Avatar
Bump. Can anyone confirm this for me please!?!
Old 03-10-2010, 02:34 PM
sas'd22re's Avatar
Ok. Well I've gone ahead and spliced the 2 smaller 10 gauge wires from the fuse box into the new 4 gauge alternator wire. Now, near the air filter box on the drivers side there are 2 connectors on the same group of thicker gauge wires. On the 'end' of those wires it pluge into the 'end' of the wires that come from the fusebox. The other connector is in-line and around 4" down the line from the end. What does thos go to? It looks like it would connect to something up the drivers side fenderwell. Please help!!! My stupid computer crashed and I lots all of these pics telling me what goes where.
Old 03-11-2010, 12:38 PM
sas'd22re's Avatar
Bump. Can anyone help me out here?
Old 03-11-2010, 04:07 PM
annoyingrob's Avatar
That's how the alt charges the battery. It goes from the alt, into the fusebox, through a rather large fuse (80A I think), to the battery terminal.
coleypull15
11-03-2015 07:41 AM
redneck17
10-29-2015 09:09 PM
09-04-2015 09:27 AM
tj884Rdlx
08-28-2015 12:04 PM
msane99
07-17-2015 10:13 AM
Quick Reply: 86 22re alternator question
