7mge air flow meter lest see if the slow 6 can take it
Old 06-04-2009, 06:21 PM
Nashman00's Avatar
well i am sick and tired of this ty power plant and as of right now i don't have the money to do the lex swap
well i gonna try the 7mge afm but i got wide band in my car and i am going to see how much it affects the truck aka how lean will it go
other stuff that i am going to do
apexi neo ( fuel computer to fix the fuel map 7mge if there is an issue )
e fan
so wide band is installed time to see how this sucker likes fuel
oh yae tested the 7mge afm and it will work with no issues has the same scale ramp as the stock afm
stay tuned
Old 06-04-2009, 06:46 PM
dem0nk1d's Avatar
watching...
Old 06-04-2009, 07:20 PM
85excab's Avatar
the 5mge afm should work too and it already comes with a cone adaptor on the filter side. and it is the same size as the 7mge one.
Old 06-04-2009, 07:56 PM
Nashman00's Avatar
no sorry the 5m one is smaller then the 7mge
well did a nice test run ideal perfect roughly about 14.7 to 14.9 withc is good
now for the best part after 3000 ish rpm you get in the rang of 15 then sweeps to 12 and at max 11 in na car umm this can be fixed
aka she can be cleaned up alot
now i gonna try to swap in the 7mge and see what happens to my ratio's
stay tuned
Old 06-04-2009, 09:08 PM
Nashman00's Avatar
well i got good news it works with little toying around
first it's not really plug and play
the fuel ramp is just like stock
if you do direct swap it will be stupid lean and wont ideal very well like 18 ish
so i poped the cap off enriched it by like 6 teeth and bango she is roughly dead on 14.8 to 14.7
so more fuel and more air make power i have yet to drive it on the street but i will in a bit lets you know what happens
Old 06-04-2009, 09:24 PM
Nashman00's Avatar
holly mother of god it's faster wow i am so impressed it's like i gain like 20 plus in power this is must swap
i can't weight tell i put my fuel computer in and get rid of my clutch fan
Old 06-04-2009, 09:46 PM
85excab's Avatar
ive got both sitting on my bench, i'll get some pics tomorrow, they are the same
Old 06-04-2009, 10:33 PM
Nashman00's Avatar
if there the same they will have the saem part number's the gearing inside them are diffent
Old 06-05-2009, 01:28 AM
Nashman00's Avatar
well i finshed it here is what it looks like
Old 06-05-2009, 08:46 AM
Jay351's Avatar
That looks great, what airbox is that?
Old 06-05-2009, 10:32 AM
Nashman00's Avatar
the air box is from a a 90 cerssida same with the afm
the best part about this air box and why i used it it use's the stock k&n filter that i had
i gonna make vid of my truck driven soon and to show the air ratio wheil driven
Old 06-05-2009, 11:24 AM
Nashman00's Avatar
well i gonna swap in a 7mge coil as well since it's alot bigger and i have spare one
i love toyota
Old 06-06-2009, 11:27 AM
Nashman00's Avatar
well i have some small issues with this swap right now thing big but it bug me it's haven hard time reseting the stock mix nothing bad a/r are still with in spec
i have better way of doing this and would be simple drop in as well would be to swap the injectors for 7mge ones
but i tried to find out what size stock are right now
any one know or have a pic of the stock ones and if there high or low Resistance
Old 06-11-2009, 05:00 PM
Nashman00's Avatar
well my fuel computer is installed (apexi neo)
mods so far are
supra afm 7mge
NM custom intake pipe
rez delet
NM shifter
apexi neo
Supra ig coil
supra spark plug gap
flex alight e fan
supra big body alt
it's time to tune and add some fuel and say good by to my milage heheh
but the power will be worth it
going to do some light tuning tonight but for now here is some pic's
and video
http://www.youtube.com/watch?v=Elj78gx67aM
Old 06-12-2009, 04:57 AM
DieselGuy's Avatar
bigger difference in the fan clutch swap, the AFM or the tuner ?
Old 06-12-2009, 07:16 AM
Nashman00's Avatar
afm i am guessing but all in all they all work togther
fan will just be a fan
on another note look liek going to get a new 02 sencer sinc ei find mine to be a tad slow
Old 03-15-2011, 04:56 PM
suprathepeg's Avatar
So one can swap in a supra AFM and enrich it 6 clicks and run it with the factory setup?
Old 04-28-2012, 02:43 PM
bone collector's Avatar
It works it works!!!!
Old 04-28-2012, 02:45 PM
Yes i know this is an old thread. I just performed this swap on my 94 3vze ext cab. The short answer to your question suprathepeg is YES. I drilled out the air idle bypass screw, set the cog 6 teeth rich and built an ISR which took the longest time. i plugged in the afm and started the truck. it stumbled a lot at first but i adjusted the air idle bypass screw IN and it ran great. i re-timed the truck played with the idle to get it to be correct. i quick test drive confirmed that this a very good mod for any 3vze owner looker for power. By the time i finished playing with the idle control and timing i had the throttle body idle screw most of the way out as well as the afm idle screw most of the way out. the timing on my truck is set at 15*. As a side note i also have the the supra coil installed and 8 mm wires. As Nashman00 said..THIS IS A MUST DO MOD!! my 3vze is now a hot rod
thanks to Nashman for the write up
Old 04-28-2012, 06:01 PM
bmcghie's Avatar
I'll bite... looks like an interesting plan!
Ummm, what can I expect to change mileage wise?
Quick Reply: 7mge air flow meter lest see if the slow 6 can take it
