7.5 or 8.0 diff???
Old 09-20-2008, 05:46 PM
mrnick1979's Avatar
7.5 or 8.0 diff???
i have a 92 2wd toyota pick up 5speed and need to replace the rear pinion bearings do i have a 7.5 or a 8.0 rear end?
Old 09-20-2008, 05:49 PM
annoyingrob's Avatar
Someone correct me if I'm wrong, but I believe the 22R(E) will have a 7.5" rear end, and the 22R-TE and 3VZ-E have an 8"
Old 09-20-2008, 05:54 PM
mrnick1979's Avatar
i think it is a 7.5 but i get mixed results when i try to search the web . most links just talk about 4wd rear ends. if it is a 7.5 i should be able to order a master install kit for a front 7.5 ifs diff.
Old 09-20-2008, 05:56 PM
Hayes's Avatar
okay... Toyota's have an 8" rear end. The 7.5" diff is for your front diff on the IFS.
Old 09-20-2008, 06:05 PM
mrnick1979's Avatar
it is a 2wd not 4wd.
Old 09-20-2008, 06:10 PM
Hayes's Avatar
I'm still fairly sure...
Old 09-20-2008, 06:24 PM
mrnick1979's Avatar
i need to know for sure i will have to order the parts and dont want to order the wrong kit. anyone else know?
Old 09-20-2008, 06:26 PM
Alex 400's Avatar
I think you have a 8", 2 pinion model. the v-6 and turbo models came with a 4 pinion unit.
Old 09-20-2008, 06:36 PM
Hayes's Avatar
I thought all Toyota rear-ends from 79-95 were 8". But I have nothing to confirm this...
Old 09-20-2008, 07:50 PM
Alex 400's Avatar
I think you're right, but the the two wheel drives i think have a different axle bearing setup and they have 5 bolt hubs I believe.
Old 09-20-2008, 08:18 PM
red97taco's Avatar
All 4 wheel drive rear-ends were at least 8in, however the 2 wheel drives can have either a 7.5in or a 8in rear-end. What are the first two letters/numbers of your vin? What is your axel code(should be on the plate inside the driver side door jam, and it is a letter followed by three numbers)?
The following users liked this post:
JoeS (12-21-2022)
Old 09-21-2008, 06:23 AM
Team420's Avatar
^x2...if the axle code starts with a "g" its an 8" diff.
Old 09-21-2008, 05:00 PM
mrnick1979's Avatar
i dont see an axle code the only code i found was, c/tr 202/fj11 a/tm a01a/w55 the oil drian plug is on the passenger side if that helps the vin starts with 4tarn81a3
Old 09-21-2008, 05:09 PM
Robert m's Avatar
from everything i have read if you have a 22r/22re and a 5speed or auto then you have a 7.5'' rear. if you have a 22rte or a v6 then you have an 8'' rear.
Old 09-21-2008, 07:32 PM
red97taco's Avatar
Yes, you have a 7.5 inch ring gear, and according to the axel chart you have 3.42 gears (this is not written in stone), and it is a 2 pinion open diff.
Old 09-21-2008, 10:55 PM
bigtrucknwheels's Avatar
Location: Where it always works if you work it, in Sunny Selinsgrove, PA
for reference, all 4WD trucks came with an 8" rear end, 2 pinion differentials for the 4 cylinder trucks and 4 pinion differentials for the 6 cylinder trucks.
2wd trucks had 3 rear end possibilities.
7.5" rear end in a 2 pinion form or an 8" rear end with either a 2 pinion or a 4 pinion setup.
ALL V6 trucks 2wd or 4wd, would have the 4 pinion 8" rear end from factory.
now, whether or not you have a 7.5 inch rear end or an 8" rear end can only be determined by the axle code or a visual reference.
it appears you have a US built truck, which makes it a lot harder to decode the axle. unfortunately for you, there are many complete axle decoding tables for Japan built trucks, but very few rather sketchy tables for US built trucks.
I believe that the 7.5" carrier is going to look different from either version of the 8" carrier. if you know anyone with a 4runner or 4wd pickup, take a look at their differential and compare it to your own. preferably a 4 cylinder 4wd pickup, as that would be the closest thing to yours. you would be able to see right away if it was a 7.5" rear end or an 8" rear end.
best of luck.
and this is from the FSM.
Old 12-12-2008, 07:33 AM
Camach's Avatar
I'm looking into an aussie locker so I was kinda wondering the same thing.
I found this website a few mins ago.
http://home.4x4wire.com/erik/diffs/#v6/turbo
Half way down the page it talks about the rear diff.
But what now is confusing me is the website says
All pre-'95 4-cylinder 4wd mini-trucks & 4Runners use the Toyota 8" 2-pinion differential front and rear (except turbo models). This is known as the "4cyl diff." This diff is by far the most common diff in older Toyotas.
Ten 10mm ring gear bolts, 27 spline pinion shaft.
Aussies website has lockers for 8" rear gear 30 spline or 7.5" rear gear 27 spline.
I presume I still need the 8" rg 30 spline but I just want some reassurance before ordering.
Sorry didn't try to hijack the thread
Old 12-12-2008, 08:46 AM
red97taco's Avatar
Yep, that is one of the best Toyota axle tech sites.
Basically he is right.
Where you highlighted his quote, it is talking about 27 spline PINION shaft. This is where your driveshaft flange is bolted on to your pinion(the big nut holds it on).
What you are wanting to know is about axle splines and ring gears. Yes the 86-95 rears are 8" ring gear and 30 spline axles. UNLESS it is 2 wheel drive.
What you see on the site might be talking about front lockers.
Sorry I had a whole bunch of info written, but it got erased when I whent to post.
Post up your vehicle information and I will try to help you out. (truck or runner, 2or4 wheel drive, and engine info)
Old 12-12-2008, 09:00 AM
Staff
DeathCougar's Avatar
A01A axle code.
Therefore, he has a 7.5", 3.42, 2 pinion diff.
The 4cyl 2wd trucks did NOT come with an 8" diff.
*edit* crap, this is a thread from September. Looks like i am late to the party.
Old 12-12-2008, 09:05 AM
Matt16's Avatar
Correct me if I'm wrong, but some one-tonne trucks came with the 4 cyl and a 8" diff.
Quick Reply: 7.5 or 8.0 diff???
