5vz head gasket
Old 05-08-2013, 11:50 AM
Tyler1820's Avatar
5vz head gasket
I am in the middle of a 3.0 to 3.4 swap and am replacing head gaskets I called the local parts store and they want like 450 bucks for the kit but I went online and found a set that came with head bolts for 90 whats the deal?
Old 05-08-2013, 12:32 PM
SacRunner's Avatar
Quality.
Pay the extra money and get the full top end gasket kit from Toyota for $450-500, it has every gasket you'll need. While you're there order new head bolts, they're $16 each (I think) and you'll need 16 of them; those bolts are one time use only.
I ended up buying another 3.4 from a local junk yard rather than replacing the head gasket on my original donor 3.4.
Old 05-08-2013, 12:43 PM
Tyler1820's Avatar
Thank you I will do that. What did you do for your exhaust?
Old 05-08-2013, 12:48 PM
SacRunner's Avatar
Toy Only Swaps crossover (http://www.toyonlyswaps.com/Page_4.html) to OEM down pipe collector (2->1) then took it to a muffler shop and had a CA legal cat installed with 2 Denso O2 sensors in their relative position to the factory locations.
I'm in California and had to go through the whole SMOG ref inspection and had to follow all the rules to keep all the emissions related components as close to factory as possible.
Old 05-08-2013, 01:07 PM
Tyler1820's Avatar
I'm in Oregon so I don't have to worry about that what would you reccomend for a good budget muffler?
Old 05-08-2013, 01:17 PM
SacRunner's Avatar
Not sure, I had the shop tie it back into the 50 series Flowmaster I had on the 3.0.
kgcwb44
01-29-2023 10:02 AM
the1998sr5
15
07-14-2020 08:35 PM
Colington
03-08-2020 09:51 AM
09-04-2015 09:27 AM
Coreyr384
07-10-2015 11:13 AM
Quick Reply: 5vz head gasket
